Thanksgiving Present!
look at what i got for thanksgiving
1.6 NA roller tips and comp cams 918 beehives with all parts to go with it! i wanna do a cam late winter or so and figured id need a new valve train anyway. i just have afew questions about what ill be doing. i plan on changing out the valve springs with the heads on the car, i know to use the air to keep the valves up but has anyone had any problems doing this or anything similar ? and secondly. im not 100% sure about the guideplates (part # TFS-30400623-8 on summit) they get mounted under the rocker stud ?
i did my valvetrain with my heads on the car. Do yourself a favor and get new valve seals, there stupid cheap, easy to change and will help with the spring install.
Whatever cylinder your working on, make the piston TDC. Then use your spring tool and take off yuor old springs. Dont worry about dropping a valve, it will just sit on top of the piston and it only drops about 2mm anyways so no worrys at all. Then when you put on the new valve seals it will hold up the valve while you put on the new stuff. Did it to my car so i know first hand it works and its less of a headach then dealing with air crap or string, i even heard of using wood, lol. No need. Hope that helps... And just curious, why didnt you go with full roller rockers as opposed to just stamped with a roller tip?
When I did mine I used a compression test hose and just hooked it up to shop air and you couldnt even push the valve down if you wanted to
just use a hose like that and hook it up to your air compressor or what have you and it will hold them up great
thanks alot guys for all your help! i feel alot better about doing the swap now. stupid me didnt realize about even putting the cylinders at TDC. so ill def be doing that. just gotta hope its there
to Taubr Unit the reason why i got the stamped roller tip vs the full roller is because i put the money into better valve springs. i was going to get the full crane kit. but its out of stock everywhere. theyll do the same jub. maybe alittle more friction but i wanted better valve springs while staying within some kind of budget to not break the bank
and to StealthFormula. thanks for the pic! ive been looking for one just like that. do you remember the part # to your studs ? i have the arp stud kit that says it has the locators for the guide plates but i dont think it does
thanks again for everyone for the help
Looks good! Have fun with the install. Do you have any before dyno or track numbers? I'm curious as to the gains you'll see with the rockers. Good luck getting it all installed!
