LS1 clutch in LT1?
I'm pretty sure they're different, they have different input shafts. I did a quick search in the manual transmission forum and it yielded this: https://ls1tech.com/forums/manual-tr...questions.html
Pretty sure the LT1 uses a pull clutch (Valeo style) due to space limitations and the LS1 uses a push clutch. The LS1 T56 has a longer input shaft (which I need if anybody has a spare) than the LT1 T56 and I also believe the the bell housing is a shorter distance between the motor and tranny. From what I have encountered in my T56 swap research for my Chevelle is that the clutches are not interchangeable, but this is just reading between the facts that I have found and using them as clues.
