LS1 clutch in LT1?
Old Nov 22, 2008 | 11:49 PM
Green3spd's Avatar
Default LS1 clutch in LT1?
Like the title says...
Can you use an ls1 clutch in an lt1 car???
Maybe a dumb question but the T56 is somewhat new to me...
Old Nov 23, 2008 | 12:02 AM
zjt's Avatar
zjt
I'm pretty sure they're different, they have different input shafts. I did a quick search in the manual transmission forum and it yielded this: https://ls1tech.com/forums/manual-tr...questions.html
Old Nov 23, 2008 | 12:35 AM
Green3spd's Avatar
guess I couldve done that, lol
Old Nov 23, 2008 | 01:28 AM
the_merv's Avatar
Veteran: Air Force
What part do you want to use.. just the Clutch itself, or the whole assembly?
The Pressure Plates are different, the LT1 Pulls, the LS1 pushes.
Old Nov 25, 2008 | 01:19 AM
crookedbowtie's Avatar
Pretty sure the LT1 uses a pull clutch (Valeo style) due to space limitations and the LS1 uses a push clutch. The LS1 T56 has a longer input shaft (which I need if anybody has a spare) than the LT1 T56 and I also believe the the bell housing is a shorter distance between the motor and tranny. From what I have encountered in my T56 swap research for my Chevelle is that the clutches are not interchangeable, but this is just reading between the facts that I have found and using them as clues.
Old Nov 25, 2008 | 05:31 AM
the_merv's Avatar
Veteran: Air Force
The LT1 Bell Housing is shorter.
Old Nov 25, 2008 | 09:25 AM
IllusionalTA's Avatar
besides the ltx style hydraulics.. are worlds better than that lsx style crap...
Old Nov 25, 2008 | 09:42 AM
the_merv's Avatar
Veteran: Air Force
There is more problems with the LSX Hydraulics than the LTX..
