Drag Racing Results - Made a "few" passes, found out a few things
rel3rd
11-23-2008, 06:28 PM
Ran at Cecil County Dragway today during a private track rental.
I made a few passes (LOL) and also found out a few things about my car.
MY TIMESLIP INFO
Run - 60' ---- ET ---- MPH
#1 - 1.60 - 11.71 - 115.70
#2 - 1.62 - 11.70 - 116.09
#3 - 1.59 - 11.69 - 115.91
#4 - 2.43 - 15.28 - 73.00 (SPUN BAD and just cruised through)
#5 - 1.63 - 11.74 - 115.35 (tried adding 2* timing @ wot)
#6 - 1.58 - 11.66 - 116.22 (back to previous tune)
#7 - 1.59 - 11.66 - 116.14
#8 - 1.59 - 11.64 - 116.29
#9 - 1.60 - 11.72 - 115.43 (tried subtracting 2* @ wot)
#10- 1.60 - 11.70 - 115.90 (back to previous tune)
#11- 1.61 - 11.67 - 116.01
#12- 1.57 - 11.61 - 116.51 (New Best) (raised 1>2 shift rpm 100 rpm's)
#13- 1.57 - 11.62 - 116.45
#14- 1.59 - 11.67 - 115.74
#15- 1.58 - 11.63 - 116.46
#16- 1.60 - 11.64 - 115.84
#17- 1.57 - 11.62 - 116.32
#18- 1.61 - 11.66 - 115.75
#19- 1.57 - 11.62 - 116.17
#20- 1.57 - 11.65 - 115.50
#21- 1.59 - 11.66 - 115.71
#22- 1.57 - 11.62 - 115.93
#23- 1.58 - 11.67 - 115.52
What I found out:
1. My car LOVES being hot-lapped
2. The cutout makes no difference whatsoever (over my SLP dual/dual catback)
3. My car runs the same ET/MPH/60 foots with 342 gears, as it does with 410's.
4. My car runs pretty much the same 60 foots regardless of foot brake launch rpm.
5. If I didn't redlight every other pass, I'd be a helluva bracket racer, lol.
Unstang
11-23-2008, 06:33 PM
Congrats on the new best, you got your money's worth!!! I love looking at a list of consistent passes at the end of a track day too.
rel3rd
11-23-2008, 06:39 PM
I had a blast. It was great running pass after pass to end the season, just like I did back in March to start the season. :D
My previous record was a mere 21 passes, lol.
http://www.ls1tech.com/forums/drag-racing-results/887596-made-few-passes-mir-lol.html?highlight=
MATTREDSS
Congrats Bob on the new pb!
Matt
rel3rd
11-23-2008, 06:40 PM
Matt
Thanks Matt. I just couldn't get that 11.5 though. :bang:
Hardtop
11-23-2008, 06:42 PM
Congrats. Damn I thought I was doing well to get 9 runs in at MIR. You got 23.:eek2: When did you switch to 4.10's ? Are you still running the 226 cam? Your car is running well.
ndfrsd6
congrats man very consistent
98blueSScamaro
11-23-2008, 06:48 PM
Congrats nice run's
rel3rd
11-23-2008, 06:54 PM
Thanks guys!
I already took them out. I made a half dozen passes a few weeks ago with the 410's. I got a new best (that I beat 6 times today with the 342's back in), but I didn't like screaming the car from start to finish at the track...not to mention what little gas mileage I got, disappeared.
Yep, still running the old tried and true hand me down PSI 226 cam. :D
Heck, I got 21 passes at MIR back in March for that rental Jason Miller had on Good Friday. :)
MATTREDSS
11-23-2008, 06:55 PM
Bob you will get 11.5s soon. Is your car full weight?
rel3rd
11-23-2008, 06:59 PM
3755# (with me in it) according to MIR's scale when I met you last March.
Probably 20# heavier at the moment...:emb:
I wouldn't mind shedding some weight off of it, as long as it didn't look like it was gone...if you know what I mean? Losing ac and stuff like that is not an option, but losing stuff that doesn't affect safety or comfort is fine.
Sharpe
11-23-2008, 07:00 PM
Nice runs. What are all your mods, including suspension and tires?
Thanks.
LS1 SPEED
11-23-2008, 07:06 PM
nice and consistent..congrats
rel3rd
11-23-2008, 07:10 PM
Thanks guys! I appreciate it.
Thanks.
Pretty simple, cookie cutter combo IMHO.
Race weight is 3755#
Drivetrain:
stock 116,000 mile bottom end
226 cam
LS6 intake
Home ported throttle body
SLP lid
SSRA (SuperSuckerRamAir)
EGR/AIR deleted
March UD crank pulley
PI Vigilante 3600 stall
Stock, untouched 4L60E
342 geared 10 bolt w/Summit girdle
Suspension:
Bilstein shocks/struts
1LE coil springs
Stock torque arm
Stock front & rear swaybars ON and hooked up
Stock, boxed lower control arms
Stock, boxed panhard bar
Wheels/Tires:
15x3.5 ProStars w/Kumho 165R15 front tires (44psi)
15x8 ProStars w/ 275/50/15 MT Drag Radials (20psi)
Tuned by me with HPTuners software w/expert help & advice from Frost @ LSxTune.com
Hardtop
11-23-2008, 07:59 PM
Thanks guys!
Thanks for doing the bigger gear experiment for me. Guess I'll stay with the 3.42's. :D
chrs1313
11-23-2008, 08:06 PM
nice times i try to tell everyone gears arent worth it in a 10 bolt...:), that is really good for the weight...
rel3rd
11-23-2008, 09:41 PM
Yeah, it was a cheap enough experiment. I swapped one of my spare 3 series carriers for a 2 series, so I could use a thick (and hopefully stronger) ring gear.
I had all of the bearings already, so I just had to buy a cheapo set of Summit brand 410's, which actually setup nice and easy, and were quiet as stock.
rel3rd
11-23-2008, 09:43 PM
Thanks a lot. I'm half tempted to swap the original 323's back in. (I only have 342's due to swapping in an older stock M6 rear)
DKITCHEN
11-24-2008, 07:53 AM
Ditto on the gear experiment! I keep thinking I need to move up from the 3.23's to at least a 3.73. I guess I'll just do the headers and catback next and see what it runs with the stock gears. Great passes! I hot lapped about 3 times at MIR yesterday and picked up mph on the both of the hot laps. Too bad I was spinning on those runs:bang:
rel3rd
11-24-2008, 08:22 AM
Glad to help, lol.
Some things we need to just DO and figure out ourselves if they work in our combos.
The gears were a perfect example.
Some insisted the car would go quicker with more gear...It didn't.
Best pass 3 weeks ago (in very similar weather) with 410's was a 11.63@116 w/1.57 60'
A year ago, I removed front swaybar, added adjustable rear shocks, Spohn chassis mount torque arm, Spohn 25mm rear swaybar, and Spohn double adjustable panhard bar.
I did this because everyone said my stock suspension was hurting performance.
Guess what? Sixty foots were worse than now with STOCK everything. My best 60 foot ever with all the suspension stuff was 1.58 (Average of 1.61). My "average" yesterday was 1.59, with several 1.57's. So...2/100ths better average 60 foots by selling all of my high dollar suspension stuff.
I run JetHot 1-3/4" longtubes, Off Road Y, SLP dual/dual catback.
Everyone swears the cutouts add horsepower, MPH, better ET, etc...
I installed one and with it open got exactly .009 better...hardly a worthwhile investment for "my car", and proof (to ME) that the dual/dual works pretty damn good. I must admit though that I left it open all day as it does sound good at WOT. :D
It looks like my car is at a plateau since no matter what I do at this point, the car runs the same...I can add timing, subtract timing, launch low, launch higher, add fuel, subtract fuel...it makes no difference.
SSIRBY
11-25-2008, 08:24 AM
nice man. and with weight, could start with the back seats/belts..
rel3rd
11-25-2008, 05:30 PM
Thankis, and you're right. I gotta start somewhere. It's not like anyone can actually sit in these back seats anyway, right? lol. :D
DKITCHEN
11-25-2008, 07:08 PM
I guess my racing weight isn't that bad since mine was 3755 on Sunday too with full leather interior and full size front tires. I'm currently trying the driver weight reduction mod too, but it's hard over the holidays!
