thinking about going turbo?
i have an 02 z28 six speed car and was thinking about a front mount turbonetics tc78 with stock 317 heads and a ls6 cam with 8-10lbs of boost. would this work well for a dd. what wastegate and bov? would 60# injectors work with a 255 pump? let me know what you are thinking!
what head gasket would i use stock ls1 or 6.0 since i would have the 6.0 317 heads? can i use 7.400 pushrods with the ls6 cam? whats a good set of valvesprings for boost. i hear double springs a like insurance?
Get a set of good GM MLS head gaskets.
Patriot or PRC duals.
7.4 Hardened pushrods.
It is all good insurance to have for the build.
Stick with a good 38mm WG and a 50mm BOV.
Dont over complicate the build.
