? about carb style intake
Old 11-28-2008, 12:23 PM
sevanseriesta's Avatar
Default ? about carb style intake
Has anyone else ever heard of this. That the carb style intake will help reduce the risk of burning up the # 7 cylinder. I have never once heard anyone say this until today.
So inspight of this new news, where is the best place to get this intake.
Old 11-28-2008, 12:49 PM
HUNTER02SS's Avatar
The carb intake will distribute the air more evenly, but as far as the #7 theory go's,unsure. I have heard about the theory, but when KP, and MightyMouse run 8's with the stock intake manifold, that kinda throws the theory out the window!
Old 11-28-2008, 01:05 PM
I would like to see more insight on this then
Old 11-28-2008, 01:10 PM
crf538's Avatar
mightymouse runs BS3 and i think you have the ability to change the individual injector duty cycles, it would be interesting to know if he runs the #7 a little richer to prevent this with the ls6 intake . I've never heard this, just thought he might.
I looked into running this intake for the same reason, but i think the single plane intake will kill too much low end torque on a setup as "mild" as mine.
Old 11-28-2008, 01:17 PM
see I was thinking the same thing. BS3 does have a couple extra functions that are stock systems will not let us do. I do not want to switch to that either.
Old 11-28-2008, 01:21 PM
HUNTER02SS's Avatar
BS3 do's have that function, but once the intake is pressurized with air, it is going to get the air it need's?
Old 11-28-2008, 01:25 PM
W8N2SQZ's Avatar
Mike Brown and crew ran their LS6 manifold all the way to 8.30's @ around 170 mph, but finally switched to the carb manifold to keep up with the heads they had changed to.
Glenn
Old 11-28-2008, 01:37 PM
on stock computer or something different?
Old 11-28-2008, 04:28 PM
studderin's Avatar
you can also just put a injector that flows more or less were you want, with the stock PCM for the same results. I do that all the time.
Old 11-28-2008, 04:56 PM
I have never heard of this also
Old 11-28-2008, 04:57 PM
I am learning all sorts of crazy stuff today...
Question about the injector thing though would that not possible make you have a miss at any other rpm range other then full throttle
Old 11-28-2008, 05:03 PM
ZLEEPER's Avatar
I was just told this by ICON who is building my car that he wanted to switch from my ported L76 to the carb style. I think it's round $400 from SDPC. Another $100 for the elbow. But WOuld rather be safe than sorry as I've got about 25k in the set up so far.
Old 11-28-2008, 06:12 PM
HUNTER02SS's Avatar
I am sure MightyMouse has the same amount in his setup as well, and Kurt is the engine builder, and they chose the LS6 intake. I am using a LS2 on my new setup. I had the Vic jr. on my old setup, but I am sure the Factory intakes work just fine. I even think they did a test on the LS6 intake by turning it around backward's to see if it moved from the #7. No ill effects when it was turned around backwards.
Quick Reply: ? about carb style intake
