over the valve cover spark plug wires?
who makes or where would i get over the valve cover spark plug wires? i didnt see any on summit, and i dont want the "cut to length" plug wires.
I made my own but Im not going to come spring for a tune up
https://ls1tech.com/forums/10485056-post8.html
Hes a sponsor and will make the wires
I personnally went with MSD wires and got the Made For You looms seperately. I'm not a big fan of the Taylor wires after having a couple bad ones. If you get a 8.5mm wire the 8mm looms may need to be drilled out a bit, mine did. I think they also make a 10.5mm otvc loom.
