installing BMR non/adj tq arm trans crossmember ?
Old 12-08-2008, 08:18 PM
metalmechanic's Avatar
Default installing BMR non/adj tq arm trans crossmember ?
BMR non adjustable tourque arm and trans crossmember, i realize that i need pinion angle + or- 2 degrees, whats the best way to determine, protractor, or will bracket line up after rear is mounted to differential? i also will be installing BMR solid billet control arms and upper and lower panhard rods.
Thanks
Old 12-09-2008, 06:08 AM
Internet Mechanic
BlackScreaminMachine's Avatar
You can buy from them a dial indicator to see where your at.
I would seriously considered not installing that for an adjustible piece.
Old 12-09-2008, 09:33 AM
what is the advantage of an adjustable? im not going any lower or dragstrip, or changing wheelsize.
Old 12-09-2008, 09:46 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Hello, the big advantage with the adjustable is you are able to adjust your pinion angle. If you have the torque arm relocation bracket you are able to do it that way also. You will need an angle finder. You should be able to get one from your local hardware store. If not we have them also. I will post you a link to our site, we have a video on how to set your pinion angle. It shows you the proper places to take the measurements from. If you need additional help give me a call.
http://www.bmrtvonline.com/video_detail.php?mId=3788
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 12-09-2008, 10:16 AM
Bad Blue WS6's Avatar
i love my non adj BMR TA,,,i dont have a need to change things on a grocery getter, and im stock height, etc. Price was right as well. One of the very few parts i actually bought brand new. Very stout, well built piece.
Old 12-09-2008, 01:48 PM
yes i have the BMR relocation bracket also, what would be reasons to change pinion angle, i am assuming it would be because of severe mods i have done to my car.The instructions that come with it seem pretty self explanitory. Ill start by trying to get it as close to the same angle that it is now. I asume i should change the relocation bracket first then mark the angle the the oem tq arm is in angle is the plane.
Old 12-09-2008, 01:55 PM
Damn, that car looks familiar
Old 12-09-2008, 03:24 PM
all the cool kidz get NBM.
Old 12-09-2008, 04:04 PM
BMR Tech2's Avatar
Thanks for the support!!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 12-09-2008, 04:35 PM
Jditlfm's Avatar
I agree my adj Bmr TA was very well built i never had a problem with it. I even bought it used so that goes to show ya something also.
Old 12-09-2008, 08:42 PM
Badazz 97 TA's Avatar
very stupid question, how do you take apart the clamshell factory mount? i cant figure that out. like how it opens or whatever???????
Old 12-09-2008, 09:14 PM
uhh , iill be doing that tommorrow hopefully i willl figure it oout myself
Old 12-10-2008, 08:45 AM
I think the two pieces will come apart once removed from the tranny,,,,but the lil black rubber parts that are attached to the two seperate sides will need to have the rivets holding them in removed,,i used a diegrinder to make quick work of it. Once those rubber halves are out, you will use the two metal parts to "sandwich" your red bushing....it took me a minuite to figure which side was what with the red bushing, but if you match the contours of the bushing to the ones in your two metal halves,,you'll get it. Be sure to grease up your TA end that goes in the bushing to make life a lil easier...i did my rear (M12 with BMR TA) on the ground first (TA attached to the rear) and lifted the whole unit in the car, starting with the tip of the TA into the red bushing.
