What cam would be better?
For a C5-427 all the bolt on's.I have the Texas giant cam 248/254 .615/.622. The car pull's up to 7k rpm easy,I really like this cam,But you know,Alway's looking for that little bit moreWould one of these cam's make alittle more power from Comp cam's-255/263 .624/.624 115LSA-------259/267 .624/.624 115LSA
I have Patriot heads but I'm in the process of putting on Livernois stage 3R heads on because the Patriot heads were for a 3.90 bore.As for compression I'm going to guess about 10.5.I had about 3 or 4 different cam's in and the Texas giant seem's to be the best one I have in it so far.........Thanks.............Paul
Its a 114 LSA.I drive around town with no problem with a SS4000 Yank TC.My idle is set in drive at 1000rpm and park is at 1100rpm.It doesn't seem to like anything lower.I had 3 different cam's in the car,They would stop pulling around 5800 to 6000rpm,The Texas giant cam seem's to be the best one so far,It pulled up to 7000rpm no problem............Paul
i have the giant in my 383 mine idels like DRIVER456 stated.... hell can even drive in town with ac and dosent even bogg the motor... its a very proven cam mine is on a 112 LSA and pulls like a **** great cam
LS1Tech Premium Sponsor
Agreed, more compression will be even better! Since you're getting new heads, now is the time to get that bump in compression via chamber size!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
