What springs and prs to go with?
Old 12-14-2008, 12:35 AM
Mean87SS's Avatar
Default What springs and prs to go with?
With a 224 cam on a stock 99 camaro... cam only swap.
Thanks.
Old 12-14-2008, 01:00 AM
01ssreda4's Avatar
pac 1218s. search
Old 12-14-2008, 09:21 AM
405HP_Z06's Avatar
In no particular order:
1. PAC 1518
2. PSI 1511
3. Patriot Golds
Here's a pressure comparison of these three. I wasn't sure what the total lift was so I used .581"
Old 12-14-2008, 10:19 AM
SOMbitch's Avatar
Whatever you do go PAC behive. I don't think you need a double with that cam. A single will be lighter and your rockers will be better off with slightly less open spring pressures.
Old 12-14-2008, 11:05 AM
01ssreda4's Avatar
1218s beehive good to .600. perfect for you. 1518s nitrate beehive good to .650. match up your seat pressures and **** too bc i know someone will chime in with that.
im running the 1218s with my tr224 114 .564
Old 12-14-2008, 11:20 AM
mike13's Avatar
01ss does that came have any lope or chop to it?
Old 12-14-2008, 12:19 PM
99_SS_LS1's Avatar
I have the 1518's with a .609 lift
Old 12-14-2008, 05:44 PM
01ssreda4's Avatar
it does have a good lope. when my idle was still at factory it would chop pretty good. my tuner raised it 100 rpm bc it was dying when coming to a stop so it smoothed out a little but with duals and dumps you KNOW the cam is there. no way you could hide it.
