Having issues with Moser 9"
Old 12-14-2008, 10:07 AM
G-NastyTA's Avatar
Default Having issues with Moser 9"
I started on the install yesterday with some friends, have the rear end out and got the brake plates off. In the write up it says you need to have the bearings pressed onto the axles in order of: Hub, Backing plate, Bearing, and Bearing retainer. My axles came with the bearings pressed on them exactly like this . Am I missing something or is something wrong??
Old 12-14-2008, 10:45 AM
the_merv's Avatar
Those look like a setup for a Mustang..or something that uses a standard 9", not the newer F-Body setup.
The way you need them setup for the F-Body is like this..
Those black pieces of Steel are what they are calling the Brake Backing Plates, I call them the Caliper Brackets.
Here they are bolted in..
Yours are definately for something other than a 4th Gen F-Body. I would send them back with your Caliper Brackets, and then have them press the Brackets on to the new Axles. I say new Axles cause I highly suggest you get ones that have the hole in the Hub like mine do to, if not then it's pretty much impossible to bolt them on.
Old 12-14-2008, 10:51 AM
G-NastyTA's Avatar
Did yours come with those? I was just going to reuse the backing plates off of my old rear end, Moser said you could. The only problem is the bearings are already pressed on and there isn't any way to get the backing plate where it should be.
Old 12-14-2008, 10:54 AM
the_merv's Avatar
No, those Plates are from my 10-Bolt. I took them off, and painted them, then pressed everything on when I recieved all my parts. I had the Center Section assembled, I put the Axles together.
I edited my first post BTW, I added that extra pic, and some info about your Axles that you might want to know before you chuck some Tools..
Old 12-14-2008, 10:56 AM
G-NastyTA's Avatar
Ah sorry mine do have the hole to bolt them on, I was just referring to how the bearing was already pressed on when I got the axles.
Old 12-14-2008, 11:35 AM
G-NastyTA's Avatar
Really the answers I need are did your axles come with the bearings already pressed on, and if not is there anything I can do? I brought it to a transmission shop and they said since the retainer ring is already on they can't take it off without damaging the bearing.
Old 12-14-2008, 11:42 AM
the_merv's Avatar
I pressed my Bearings on to mine, they came fully dis-assembled. I requested it that way because I knew how to do it, and I had my Backing Plates already.
Old 12-14-2008, 11:45 AM
danhr's Avatar
They sent you the wrong thing. You have two options
1) Buy a new set of wheel bearings, take your axles to a machine shop and have them remove the current ones and put on the back plates, abs reluctor ring (if you have 4 channel abs), and the backing plates. You can't not reuse a wheel bearing after it's been pressed on, because when they put a clampshell on it to press it back off, it damages teh wheel bearing.
2) send the axles back to moser and tell them to send you the right axles (which would be the same axles except with nothing pressed on). This would save you the cost of buying new wheel bearings.
G-NastyTA's Avatar
Nothing on mine was assembled aside from that, which doesn't make any sense at all, the only thing I can think of is they sent me the wrong axles. They fit alright, but there isn't any way to put the backing plate on due to the bearing already being pressed on.
Old 12-14-2008, 11:47 AM
G-NastyTA's Avatar
Is there any where I can pick up a wheel bearing today? I know it's a Sunday but I need to get it finished, it's going in my street car which is now laying in pieces.... I have to make it to class and work tomorrow.
Old 12-14-2008, 11:54 AM
danhr's Avatar
Any parts store will have it. the ones they stock just won't have that o-ring to help seal the axles. just remember to use some rtv
Old 12-14-2008, 11:56 AM
G-NastyTA's Avatar
Thanks a lot you guys for the help, I'll go see if I can't figure somethin out
Old 12-14-2008, 12:10 PM
EPP
EPP's Avatar
Tell them you need bearings for a 1975 Ford Pick-up. That will get you the correct bearings. The bearings should never come pre-installed on the axles unless the customer request they be installed. Bob
Old 12-14-2008, 01:34 PM
G-NastyTA's Avatar
Do you know exactly which truck it would be on?
Old 12-14-2008, 01:48 PM
danhr's Avatar
Say you need two wheel bearings for a 1999 ford bronco.
66-71 bronco's had 9"
the_merv's Avatar
I never knew there was an O-Ring, I've always used RTV..
Old 12-14-2008, 01:50 PM
G-NastyTA's Avatar
I looked at the bearings for an '82 Ford truck which also has a 9" and it wasn't the right one, I'll look at the wheel bearing for the bronco and see what it looks like.
Old 12-14-2008, 03:04 PM
RooRnZ28's Avatar
moser did this to me as well.... also make sure that the axles are the correct length!!
Old 12-14-2008, 03:08 PM
G-NastyTA's Avatar
I'm just going to ship them back tomorrow and have them overnight me new axles. I haven't exactly had a nice experience with Moser
Old 12-14-2008, 04:36 PM
C_B64's Avatar
Mine came unassembled..... I pressed mine on myself... Mine also didn't have the hole in them either. Had to take the e-brake apart to tighten them up...
Quick Reply: Having issues with Moser 9"
