2001 z06 dyno results
My 01 z06 has Belanger LT's, catless corsa X, B&B PRTS, breathless performance CAI, i dynoed 367 HP 367 TQ, this was done on a dynojet.
It is tuned, before the tune the baseline was 357/357, i was expecting a little higher as well but as my tunner said thats good for an 01 considering 02-04s would be 20 more which would be 387 which is good for an 02-04Z
I have a set of Kooks LTs on the way and was just wondering what I could expect with the new mods....
Once again, nice numbers man.
Thanks! you must have a factory freak or the dynos were off, 02+ usually dyno that and if ur stock thats damn good!! way to go! with LT+tune you should see 20 more RWHP i would say. let me know when you get em on and dynoed!
sounds about right...
I had a 01 LS6 long block put into my car...on the stock LS1 tune with intake/headers/exhaust and ported throttle body on a Dyna pack dyno (read 10% lower then a dyno jet I was told by the owner) without a Tune I made 351rwhp and 355rwtq.
so on a dyno jet I would be in the same ball park as you....a little higher if I got a dyno tune.
I dont have any real track times with the car yet.... Only time I went with the car, the track temps were 168 degrees!!! It was the hottest day of the year at the track and everytime they tried spraying VHT on the track, all it did was make it worse....
Im hoping to make in the 380s with the LTs and a tune....
Well my first thoughts were that the dyno was off, but the same day a C6 Z06 dynoed within 15 min of me and he put down 443rwhp.... Which is the norm, so.... I would just have to say that its alil on the freak side.
I know some people go from a drag rim to street/show tires/rim and can loose 20hp on the dyno.
^^^^ I have the Black w/Chrome lip Z06 Motorsports.... 17s front and 18s rear. I would guess going from the gunmetal ones to chrome would only lose a few hp. My friend went from the stock 18s to some 20s and only lost 8rwhp, so....
Ill definitely keep you in check though....
