Changing set up need help
I recently planned a set up with the vrx5 cam and decided to change to a custom grind cam. I was hoping yall think i would run into any problems with this set up.
Stock bottom end ls1
Comp Cam- 230/230 .612 .592 111+2
TSP ported Ls6 oil pump
Comp 850-16 lifters
Comp Chromemoly 7.4" Pushrods
241 heads ported with stock valves and 220cc intake runner
TEA Dual .650 lift dual vavle springs
ls2 Timing Chain
LS6 Intake
FAST 36lb Injectors
YankSS3600 Stall
3.73 Gears
Texas Speed 1 7/8 Lontubes
Cutsom Y and Loud mouth with sweet thunder
Ill also be using all stock gaskets
Comp 850-16 lifters
ls2 Timing Chain
LS6 Intake
FAST 36lb Injectors
YankSS3600 Stall
3.73 Gears
I talked to john i believe it was at TSP and they siad the problems there are is with older motor mounts bein sluggish on the older cars. He said newer modles have chromemoly and dont have that problem
Been told to mill the heads a little to increase compression. Anyone have any suggestions on the milling? After talking to a few people we came up with the possibility of milling .015 and running a .040 gasket.
Any input?
Any input?
That was about as big as I could fit without recessing valve in my setup.
Also search Chrs1313. He is stock headed with same duration 111LSA cam and originally set it up with 4* advance but after checking PTV backed the advance down to 2* to gain more clearance and keep it safe IIRC.
Maybe he will chime in here.....
EDIT: Here ya go
http://www.ls1tech.com/forums/genera...m-curious.html)
EDIT: Here ya go
