Spools - any difference between them?
Old 12-15-2008, 08:51 AM
Javier97Z28's Avatar
Default Spools - any difference between them?
Any difference b/w 'em? Or is a spool a spool, no matter if it's lightweight or not?
I know the ups and downs to 'em, not worried about that... just looking to get what will work best at the strip.
I'll probably pick something like this up..
http://cgi.ebay.com/ebaymotors/9-For...Q5fAccessories
Old 12-15-2008, 10:06 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I dont have a spool, but rather a Eaton Tru trac thats a mix of a Spool and Detroit Locker which is a PITA when the fluid in the diff is cold.
As for the spool itself, my understanding the diff was between street use and track use and i am not sure an alight weight aluminum spool is ideal for street use.
Again I am no expert but if they didnt offer other options, there would be a reason, and everyone would use the lightest one possible.
Old 12-15-2008, 02:39 PM
ssfast99's Avatar
yes some spools are different then others. the general concept of the spool is the same for all. howver some have thicker housings and mounting points. also a mini or aluminum spool is not for regularly street use. you shouldnt be worried about a couple pounds that sit over the tires.
Old 12-15-2008, 07:16 PM
getusum's Avatar
You don't want the one you posted up.....It is for circle track cars....IMCA..
Old 12-15-2008, 09:34 PM
Ah ic, that's where my concern lies. How do you differentiate b/w 'em?
Old 12-16-2008, 12:08 AM
getusum's Avatar
Usually it will say street/track/drag....etc etc.....Go to the same site you found that one on and give the guy a call.......He'll help ya,,,,,
Or, Call Bob at EPP.....he'll point ya in the right direction...
Todd
Old 12-16-2008, 07:20 AM
Thanks Todd!
Old 12-17-2008, 07:49 PM
getusum's Avatar
Thanks Todd!
No problem, glad I could help.....After 2 yrs on this site and all the questions I've asked, glad to see I could return the favor....
Old 12-22-2008, 08:53 PM
bad6as's Avatar
i was told not to get aluminum and not to get light weight, from the guy from strange so i went with the strange steel
Old 12-25-2008, 06:01 PM
TJ
TJ's Avatar
i was recommended to check with the axle manufacturer to see what pressure angle the axles will accept.
i think there is 30 and 45 deg for the 9"
Old 12-25-2008, 07:40 PM
03 BUSA's Avatar
^^^There is the Mark Williams style and the not Mark Williams style. If you go with Strange Moser ect they will be the regular 30* splines.
