lt1 max amount of nitrous ??
Old 12-18-2008, 11:33 AM
baylove's Avatar
Default lt1 max amount of nitrous ??
i wanted to know the max amount of nitrous that a lt1 with the
STOCK BOTTOM END can handle without blowing the motor or damaging it ??
Old 12-18-2008, 11:41 AM
Elliott's94Z's Avatar
Well I wouldn't go any bigger then 150. Some run 200 w/o problems but you just never really know. Nitrous Outlets Wet Plate set up is a super nice kit and you could even go with a 125 spray which would run you a extra 15 bucks I believe for that nozzel. 125 would be my first choice if I ran Nitrous. I'm working my way towards this kit.
Old 12-18-2008, 12:00 PM
MonmouthCtyLS7's Avatar
yea ive seen some guys run 200 for awhile
Old 12-18-2008, 12:05 PM
In-Zane Moderator
ZONES89RS's Avatar
I have seen retarded amounts of nitrous on stock small blocks. If the tune is correct a 250 shot is easily done, but to know your rings will be fine and the engine last a while, a 200 shot is about the most you want to run, 150 is the safe zone and 100 is just going to last forever. I ran a 200 shot on a 305 for 1 year before it died, it was only because of the fuel pump going out it leaned the engine to death.
the_merv's Avatar
I'll donate a Shovel so you can scoop your Rods up off the Line finding out..
Old 12-18-2008, 12:42 PM
z28rob18's Avatar
id say 150 is about the limit unless u would lik to push the limit and test the bottom end
Old 12-18-2008, 12:44 PM
baylove's Avatar
alright cool merv then i can use your truck to tow it home and then i can build something else BETTER LOL lets go big its damn near 2009 i will see what happens with the 200 shot and the tune im getting all the safety parts also and i will be using the plate kit also its on the way now i wont use it all the time but i want it there when i need it i was planning on doing 150 shot but if the 200 can hold up thats what i want guess we will see what happens
Old 12-18-2008, 12:58 PM
the_merv's Avatar
Lol.. that's what I got my Truck for, it's towed my Car home a few times.
Old 12-18-2008, 01:01 PM
baylove's Avatar
LMAO that stays on my mind all the time a truck is a good investment
Old 12-18-2008, 01:09 PM
baylove's Avatar
yeah merv is a funny guy i wont need a shovel meaning in not gonan blow it merv but i have you as my sponsor just in case i do
Old 12-18-2008, 01:39 PM
the_merv's Avatar
^^That's cause you can just pick them up with your Hands..
Old 12-18-2008, 01:58 PM
pyro719's Avatar
I am also interested in spraying a 200 shot. I have been sprayin the zex 125 dry shot for like 2 years now and want to add a wet 100 shot stage. Do you guys think a walbro 255 will handle the job?
Old 12-18-2008, 02:44 PM
baylove's Avatar
i have a walbro 255 in my car now do i need more fuel for the 200 shot ? maybe bigger injectors ??
Old 12-18-2008, 02:53 PM
96lt1m6's Avatar
if you pm the guys that have N2o fed Lt1s they will tell you 150 shot all day will be finebut a 255 is strongly suggested. now when you step up to more spray your fuel system will need some mods such as:
fuel rail mods,fittings welded to the rail
braided lines from reg. to the rail
better FPR, like the aeromotive
if you do a search you will see a few variations of what i am describing.
i would be leary of hitting ANY HYPERUTECTIC piston with anything more than 175 even with an improved fuel delivey......
now that that is covered, the factory Lt1 intake will not allow you to safely run alot of N2O without sacrificing #8cyl. Baaaad things happen to this cyl. like leaning out.......so you can move on to a direct port unit(where each cyl. has its own nozzle) this will allow you to hit it with more spray etc......
question to OP why do you want such a large amout of N2O on a stock botom end? i would strongly suggest a shortblock buitl with good rods and forged pistons and instal main studs then spray the crap out of it!!!!
Old 12-18-2008, 03:04 PM
baylove's Avatar
i feel you we will just have to see what happens thanks everyone for helping out except merv
Old 12-18-2008, 03:08 PM
1badzee's Avatar
lol.. everyones a comedian on here
Old 12-18-2008, 03:42 PM
brokenbird's Avatar
i have run a 175 shot for about 40 bottles and its got 150k on it and still running strong
Old 12-18-2008, 03:47 PM
baylove's Avatar
175 is good enuff for me
Old 12-18-2008, 09:02 PM
brokenbird's Avatar
yeah thats a deffinate difference thats why i stoped there
Quick Reply: lt1 max amount of nitrous ??
