what k-member are you running?
i am looking at an AJE Moly K-member. anyone know anything about em on an f-body? i had one on my 89 coupe and i was happy with it. also what is the advantage of the pinto rack?
I'm also curious about the AJE K-members for our 4th gen f-bodies, also the AJE A-arms. There's AJE A-arms on Jegs that say "for f-body Camaro" but doesn't specify years or anything.
(I know the OP is almost 2 months old, but I figured I'd bring this thread back rather than start a new one.)
I'm running a stock K-member and Stock lower control arms because they are the only pieces available that hold up the riggers of autocrossing and road racing, especially with my 315's on all four corners.
yeah if you go to http://www.ajeracing.com/there isn't alot of info either. i guess i'll just call them and ask some questions. i'll post up the answers i get.
Major my application will be drag racing. i am looking for the wieght savings. i'm not sure of Cav's app but i am guessing the same as mine.
I think for most drag race only applications you should be fine, unless your car can do a wheel stand, then you may want to re-consider because when that front end comes back down a pretty good load is seen by the Lower A-arm and K-member.
PA is what i use if it it has to be lite . I have used a few BMR s , both are good but the pa is chrome-molly or mild steel where the BMR is Mild only are used to be.
K member
We do have two versions of K members Kits, One is a Road Race version and the other is a Street version that cuts 25lbs off the front end! And with both versions you do have the option to upgrade your A arms to 4140 Chrome Moly Steel! If you have any other questions feel free to contact us and I will be glad to help!
Thanks Again,
Brad
Thanks
Thanks Again,
Brad
Thanks Again,
Brad
LS1Tech Premium Sponsor
Most of the big horsepower drag radial F-Body racers use the BMR K-member.
BMR K-members are made from DOM steel, not chrome-moly. That means they are a couple of pounds heavier than the 4130 K-members.
However, the BMR K-member can also be used on the street. Many of the chrome-moly K-members are designed as a drag-race-only component, so they don't have the extra tubing required for street driving (in other words, potholes).
Thanks
Thanks Again,
Brad
Thanks Again,
Brad
Thanks Again
Im running a UMI, as a fabricator, I could appreciate the workmanship that was done on it. I could have easily made one with my jd2 bender, 4130 tubing or dom tubing, and my ole faithful syncrowave 250, but in the end, it was so easy to make a call, order one, and when it arrived to think some companies still do take pride in what they make. I have in the past ordered different things from different MFG's (not going to bash anyone). I had all kinds of problems with my torque arm, and lca's that it left me bitter. So I built my rear suspension, lca's, tq arm, phr..... and was never going to "buy" something I could make myself Again. Well, fwiw, I would order anything from UMI no questions asked at this point. It's not worth my time anymore, because honestly, If I had a problem ( doubt I ever will), I know I could call Ryan @ UMI, and im sure it would be taken care of. Seems like a really good company, with great customer service! I even had a bolt snap, and he wasn't sure if he had the right bolt for my application, he sent out 2 size bolts for free to get me going(car had been down for months). Great company...
Thank you for choosing UMI Performance. Glad you are happy with our Products! If there is any other questions feel free to contact me and I will be glad to help.
Thanks Again,
Brad
