Better grip for better handling
I don't know if any of you have this problem, but when I drive my Z28, it is hard for me to grip the steering wheel. Since I feel more comfortable driving with one hand, I need to have the best grip on my steering wheel so I can maneuver fast and make fast u turns. I don't know if its just my car, but the outter part of my steering wheel is bald and don't know if its supposed to be like this, or its just worn out. Are there any steering wheel covers I can add which would give much better grip for one handed drivers, which would also provide grip when the hands are a little moist?
Any types of materials I should look out for which would still provide grip when the wheel is a little moist from glistening hands?
lol...naw i dont have that problem, normally i just rest my right hand on the top right side of the horn/airbag in that lil corner.
when i turn the car i typically use two hands, that's just how i was taught by my dad... sorry i cant help any. good luck though!
i use a very tight pep boys wheel cover, got one to match my interior and also one that doesnt say "TYPE RRRRRRR" just a plain black and gray one. im used to a thicker truck steering wheel so i put the cover on my f body to keep them the same.
Well its not anything about hands or anything. I got pretty big hands too, thin but big. Lets say when I'm making a U turn, ill use only my left hand to make the turn. I will use the tip of the inside of my hand. Like using the ball of the knuckle i guess. I have no problem holding on to the wheel when I'm driving. Its just when making U turns or making sharp turns quick, Ill use only the tip of the inside of my hand and turn the wheel quick like that. Not sure if I'm making it clear. But basically, there is no grip on the camaro steering wheel to keep my hand from sliding.
wheelskins makes a cover that actually stitches onto the steering wheel and is leather so it should make it a bit thicker and help with grip. you can get it perforated or what not too.
http://www.afterthoughtsauto.com/whe...one-cover.html
Like isn't it pretty obvious what to do? You need to slow down a bit, there's no reason you shouldn't be able to hold onto the wheel while making a U-turn. I don't know many places where making a 30MPH U-Turn is safe, and if you aren't making speedy U-Turns, maybe you need to work out a bit more and grab the wheel a little harder.
But if you really want to change it, get one of those steering wheel covers with the weird *** plastic things made for grip.
I guess no one really understands what im trying to say. well check out this video..
http://www.youtube.com/watch?v=zs7YW...ext=1&index=42
0:47 seconds into the video. He is only using one hand to spin the wheel at first. This is what im trying to explain. He uses more of his lower palm, while I use more of the upper palm, i guess, right below the finger.
I'm not making fast u turns. I want to be able to steer the wheel fast when the car is stopped for 3 point turns. And holding the wheel is not the problem. only the tip of my hand is actually coming in contact with the wheel when i am turning it. my hand is open so i can spin the wheel with one hand.
If you can't hold the wheel, make U-Turns with two hands.
