Painting wheels black?
My t/a is black itself.
So i have the same wheels that are in the picture. I saw a car with them painted black and the lip was still "polished" i thought it looked pretty good. I figure it would help my wheels look better untill i found some 5spokes.
What are my wheel paint options?
I wanted to paint my wheels black also. I brought it to a body shop and they told me that they wont paint them. There are some companies that will though. The one I went too told me they wouldnt do it because when the tire is mounted, 9 times out of 10 the mounting place will scrape the paint off the lip putting on the casing. Then once the tire is on the car the heat of braking along with exposure to rain water will cause the paint to bubble and crack off. Then he went out as far and rocks and crap that hit it will damage the paint. Long story short, if you are going to get your wheels painted.....make sure the company will guarantee thier work and product.
what would you recommend I do with my stockers. The clear is peeling and they look like crap. I was gonna paint them, but if I can get them to look like they came from the factory again I would.
you can find wheel paint that will hold up to the heat and dust of braking but still a rock at 70 will chip it and tire replacement will reck the lip..... You can get them powder coated but $$$$.
I painted my wheels that I used during last winter.
Here is my project thread...
https://ls1tech.com/forums/wheels-ti...wheels-ta.html
They held up great through the winter and getting different tires mounted.
Painted them both with generic cheap paint and clear coat-i re do them when i change my tires so there's no worries about the tire mounting process scratching the paint-even if they dont scratch the paint, the removal/addition of wheel weights will leave unpainted areas so i find my way easier, cheaper, and quicker. Best luck if you haven't already done them.
Last edited by batbirds; 04-20-2015 at 12:05 AM. Reason: wanted to be more descript
1 Post
I'd paint the centre cap and inside pockets black and leave the rest as silver. Plastidip should work well; if you don't like the results you can peel off. Plastidip is a cheap solution
