View Poll Results: what heads/ or change cam with heads
Multiple Choice Poll. Voters: 43. You may not vote on this poll
heads cam need good advice
ok i have posted on here b4 and asked about the same thing. ill try agin
i have a 2002 camaro m6. as of now i have a cam only car (springs pushrods all that good stuff also) next im looking into heads what heads should i run for best hp with a Tv 3 cam? or i have been told to change cam and so i can maximize hp with the heads
TEA makes a good head in between the low buck patriot/TSP and high end FT/AFR... i would recomend the TEA stg 2, LS6 head,, great medium lift numbers, and 320 cfm in the high lift end
if you have the coin.....the TFS are pretty hard to beat.
great flow
improved valve angle for more clearance
great runner size for power down low without sacraficing power up top
downside is you have to buy roller rockers along with them.
great flow
technically you dont, you can run RR's with TFS heads, but why? Really its only another 400 bucks but it will ensure perfect valve train geometry and reduce wear. I have seen where TFS says you can run stock rockers, but advises against it so strongly that they dont even consider it an option.
False statement.
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
True and that is with any head.
__________________
We will only warranty our heads if you are using roller rockers. It is not due to geometry as some seem to think. On the larger high lift cams using a stock rocker you will get guide wear on bronze guides and you will get valve tip scrubbing. This is just not on our heads!!!! We have tested many aftermarket and factory heads and they have all done it.
__________________
