need a water pump welded
Old 01-01-2009, 07:48 PM
reaperracer666's Avatar
Default need a water pump welded
anyone know where to get a waterpump welded up to close off heater lines and close off back for an electric water pump?
Old 01-01-2009, 08:10 PM
ss.slp.ls1's Avatar
Just use a some bypass caps and clamps to block off the heater hose ports. I haven't heard of anyone having to weld an electric pump on.
Old 01-01-2009, 08:11 PM
rebuilt's Avatar
Mine just has a freeze plug blocking off the hole in back.
Old 01-01-2009, 08:15 PM
not weld the pump on i took off the hoses for the heater core that go to the pump and want to have them welded shut also the drive hole in the back off the pump that is usually freeze pluged no i dont want to ****** rig it this car will also see some car shows so no ugly block offs
Old 01-01-2009, 08:16 PM
want to have it welded so there are no leaks not just now but forever welds dont leak ever
Old 01-01-2009, 08:18 PM
FlamingChicken's Avatar
well no one would see the drive hole anyway but just take it to a machine or body shop. just somebody that can tig (pretty sure aluminum needs to be tig welded)
Old 01-01-2009, 08:23 PM
not to many people tig weld at body shops even fewer tig welders weld alinium
Old 01-01-2009, 08:27 PM
i know our body shop does a little tig. another idea would be a marine shop. my dad has had his jon boat welded on a few times.
Old 01-01-2009, 10:43 PM
rebuilt's Avatar
Who is gonna see the backside of the water pump? timing cover maybe but they would have to be looking.
Old 01-02-2009, 12:27 PM
ScrapSilicon's Avatar
http://images.google.com/images?um=1...=Search+Images ... especially liked
Old 01-02-2009, 01:02 PM
crookedbowtie's Avatar
Aluminum boat shops should be able to, as well as any custom fab place. I have several in my area. I could even do it if you get desperate. I mostly TIG thin wall chromo/stainless/steel for a living, but can lay a decent bead on aluminum and have a TIG in my garage. It looks clean with the pump welded and ground instead of freeze plugs and hose clamps. I am going to weld my rear pump hole when I put an electric pump in. I drilled and tapped the weep hole and installed a fitting to run a hose away from the opti too, but don't think that is necessary with electric. Also put a petcock in the pump to drain it fast for easy access to the opti.
