Cam recommendations?
I know there is a billion threads on this already, but I'm looking to get a pretty big cam for some decent N/A power... Staying away from heads for a bit, so here's my setup.
LS6 intake mani
Whisper Lid
Ram Air
Long tubes
Straight pipes
Ported TB
Port/Polished MAF
I'm running a T56 w/ 3.42s in the rear end.
I was thinking MS4 cam but what do you all think?
Thanks.
LS6 intake mani
Whisper Lid
Ram Air
Long tubes
Straight pipes
Ported TB
Port/Polished MAF
Thanks.
I have about the same setup as you, and was in the same cituation as you but i do spray my car!!! I was going to go ms4 but thought id give tickperformance a shot with there new polluter cam! everything should hopefully be here next week... so i will be installing next weekend, if you havnt decided by then ill let you know how the polluter turns out... otherwise gl with deciding!!!
I wouldn't use that cam for several reasons: 1) You are restricted on air flow coming in due to elevation. 2) You are restricted by your intake manifold. 3) You will need deaper gears than what you currently have (3:73's or 4:10's). 4) A very good tuner to get the cam surge down to a minimum.
I would run a reverse split cam instead, something alond the lines of 236/232 113+2 for a "larger cam" feel. I know on a 346 stock bottom end car with RHS heads, FAST 90/90, MSD coils, shaftmount rockers, headers, cold air intake, 85mm Mass air, and several other bolt ons with a 238/238 112+4 cam was a bitch to get tuned correctly. I don't know of anybody in Albuquerque with this kind of talent, but I do know of a person that can get you squared away with a mail order tune (plus follow up street driving corrections involving HPTuner software w/data logging software). Ed (edcmat-l1) at www.theHPfactory.com (site sponsor) can get you going.
Well, a lot of guys here in ABQ are running decent sized cams without any problems. As for the tuning, Solid Technology is the place to go. Sean (lbz34 on here and rsw) is a great tuner. I guess I should probably ask him what cam I should go with He'll probably say ms3 and spray lol.
Yeah for sure bro. I'm still poking around doing my research, cuz you know just as well as I that N/A cars are hard to make fast up here. As for solid tech, their website is http://solid-technology.com/
You need anything hit them up, if you want a tune it'll be worth the drive.
