Proper front cover install using correct tools pics inside
Old 01-03-2009, 09:51 PM
JFM-jr's Avatar
Default Proper front cover install using correct tools pics inside
This may seems a bit simple for some of you guys who have done this multiple times so this is really just for those who have not. I'm sure some of you guys have heard of the Kent Moore tools used for LS series motors. Here are some pics below of what tools are used where and you will see why it is important.
First is the cover alignment tool this can be used for both the front and rear covers. You just use a different set of holes for the front or the rear covers depending on your needs.
Here is the other side of the plate you can see the machined slots in the surface. These provide room for the front or rear gaskets tabs that protrude a bit below the oilpan surface of the block.
Here is a picture showing the rubber "tab" on the front cover gasket that those slots are machined for. I am bending the rubber tab here
Here the plate is installed for front cover installation
It gets fatened to the oilpan /block surface 2 bolts into the block and 2 into the bottom of the front cover. This ensures the bottom of the front cover is nice and flush with the blocks surface. This will ensure the oilpan has a flat surface to mate up with as the oilpan's footprint covers both front and rear covers when viewed from directly underneath. Below is a pic of the block with both front and rear covers installed. You can see the footprint the oilpan covers here. The oilpan actually ties the lower end of this motor together and is a part of the structural integrity of these motors.
Below is a picture showing the inside of an LS2 cover with the plate bolted to it so you can more easily see where those machined slots reside.
Finally below is a picture of the front cover installed and it shows the tab that sticks out beyond the surface and the is the purpose of the slots in the plate.
That plate orients the cover up and down now the cover needs to be set correctly side to side. It needs to be centered around the crank snout so the front seal can do it's job. Here is a pic with me pointing out the 2 bosses that are cast into the front covers design. Some of you guys probably never knew they even had a purpose (I did'nt until I installed a front cover).
Here is a picture of the tool that will center the cover radially around the crank snout using the 2 bosses in the picture above. It just slides right onto the crank snout where you see my fingers sticking thru it.
And here it is installed on the cover using the crank pully bolt to seat into place.
Here is one more pic notice the 2 (of the 4) machined slots are under the front cover now and are providing a space for the front cover gasket to stick below the block/covers surface. This part of the gasket I am talking about are just small flexible rubber tabs and dont stick out very much.
When the cover is all in place the bolts get torqued down and the front cover is in it's correct place. Now I'm sure some guys may not bother with the tools at all and have no issue's. I have access to these tools and it does not cost me anything so why not use them. I just thought i'd share this process for anybody who has heard about these tools and was curious.
Old 01-03-2009, 10:22 PM
01ssreda4's Avatar
nice pics....thanks.
Old 01-03-2009, 10:33 PM
405HP_Z06's Avatar
Nice.
Old 01-03-2009, 10:39 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Well I'll be damned...
Old 01-04-2009, 06:31 AM
forcd ind's Avatar
i install the balancer in the front to align the front cover-while it is nice to have the kent moore tools, i have paid more for some of them than a used engine-build a 4l80e and price them out, lol-never thought pieces of plastic were worth so much
Old 01-04-2009, 08:17 AM
vsocks1's Avatar
What is the number of the tool for side to side alignment?
Old 01-04-2009, 08:23 AM
vettenuts's Avatar
Since I still had the pan on, I used a very finely graduated 6" metal rule to center the shaft within the seal housing. I used the OD of the seal rather than the ID since the ID of the seal isn't necessarily round.
Nice photo's, where did you get the tools?
Old 01-04-2009, 12:02 PM
BottleBaby Bu's Avatar
x10
Old 01-04-2009, 12:50 PM
405HP_Z06's Avatar
Originally Posted by vsocks1
what is the number of the tool for side to side alignment?
j-41476
Old 01-04-2009, 05:38 PM
JFM-jr's Avatar
Wait until you price that lil gem LOL. These tools are obscenely exspensive lucky for me I have a friend that works for a GM dealership. Here is a pic of the inside of the cover on the case. It lists all the tools in the kit.
These motors have special tools for everything it's unreal. I am surprised there is no airfilter alignment tool LOL.
Old 01-04-2009, 06:32 PM
Shawn MacAnanny's Avatar
Wow lol. I just dapped black rtv in the corner where in me the oil pan/block. I centered using the crank pullley method as mentioned but not all the way installed. That's neat they have tools though.
Old 01-04-2009, 08:36 PM
LS1MCSS's Avatar
Holy **** batman, that one tool is over $400.
Old 01-04-2009, 11:52 PM
Heyfred's Avatar
Thumbs up Thanks for the write up.
I am getting ready to do a head/cam swap.
So, I bought a KENT MOORE J-43145 GEN III V8 ENGINE TOOL KIT to make the job go easier and not have issues.
Old 01-05-2009, 01:55 AM
JFM-jr's Avatar
So, I cashed in my 401K plan and I bought a KENT MOORE J-43145 GEN III V8 ENGINE TOOL KIT to make the job go easier and not have issues.
There I fixed that for ya LOL.
Old 01-05-2009, 05:37 AM
eallanboggs's Avatar
If you stop and think about it, once all the front cover bolts are in finger tight and the pulley is all the way home there isn't much side to side(horizontal) movement left. There really isn't any vertical movement available either since the lower face of the cover is sitting on upper front face of the oil pan and the oil seal on the front cover is also holding the front cover fast because the pulley hub is resident inside of the seal. We must be talking thousandths of an inch in available adjustment which the expensive KentMoore tools is going to correct for. I believe it's not only over priced, but overkill as well.
Old 01-05-2009, 06:32 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
So is it necesary to use the alignment tools only when you remove the oil pan and the front/rear covers? If you only remove on of the 3, you should be able to use the other two as an alignment aid.
Old 01-05-2009, 07:10 AM
Heyfred's Avatar
Found the kit on Ebay. It was from a Chevy dealership that shut down.
Old 01-05-2009, 08:02 AM
koolrayz's Avatar
Thanks for the writeup!
After seeing the tools in action it makes it easy to see how to make something at home that will work without breaking my bank.
Old 01-05-2009, 10:39 PM
If you're just removing and reinstalling the front cover without dropping the pan I don't see why you need the expensive Kent/Moore tool. If you're doing a rebuild it might be different. If the pan is flush to the block the front and rear covers can only be moved side to side a tiny amount with all the fasteners in the pulley in place. The pan can't move fore and aft because of the front and rear covers. It can only move side to side and very litte at that once the bolts are installed. I'd like to see two engine put together side by side one using the tool and one not. Then you could compare them to see how much of a difference there really is.
Old 01-06-2009, 01:10 AM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
I first used these tools about 10 years ago. I don't use them much anymore but for the guys doing these in their garage the timing cover can be centered with a caliper or specific sized "dowels" if available. Assuming the oil pan is in place and the front crank seal is removed; the timing cover is centered when there is .680" gap around the perimeter of the crank snout to the seal housing bore. FWIW the red Snap-on 1/2" nut drivers are the correct OD .680" size also... I've often wanted to have a tapered sleeve that centers the timing cover made to make that easier.
The newer reverse lip rear main seals center the rear covers quite well without the tools, as long as the pan is installed first as posted above. I should note that if using that brass centering tool on the rear cover; the rear main seal needs to be removed, kind of a PITA if you bought a new cover with the seal already installed as you'll likely need another rear main seal.
Quick Reply: Proper front cover install using correct tools pics inside
