summit universal x pipe???????
Old 01-04-2009, 06:35 PM
sanders8800's Avatar
Default summit universal x pipe???????
Does anyone have a shopping cart or wish list for everything you need to to install the summit or jeggs universal x pipe kit???
Old 01-04-2009, 06:36 PM
AChotrod's Avatar
I have the list at work with part numbers. Ill get it to you tomorrow if nobody does by then.
Old 01-04-2009, 06:39 PM
Benner's Avatar
subscribing. Interested as well.
Old 01-04-2009, 06:44 PM
Restricted User
1BAD_LS1's Avatar
looking at running my own duals out the back this would help alot.
Old 01-04-2009, 06:50 PM
StealthFormula's Avatar
This page has everything you need:
http://www.lt1engine.com/tech/how-to...duals-exhaust/
Don't forget some turndowns if you want them, I used that page when piecing together my Summit setup. I used some nicer reducers and different mufflers and it worked great.
Old 01-04-2009, 06:52 PM
think you!!!!!!!!
Old 01-04-2009, 06:53 PM
tspence45's Avatar
Depends on what size piping you'll run. If you're going with 2.5" piping, you'll need to get some collector reducers. Otherwise, there's not really anything else you'll need. Order some single chambers off eBay, and they come with hangers and mounting hardware. Then, just take it to a shop and have them fab it up. Or, you could fab it up yourself.
Old 01-04-2009, 06:58 PM
AChotrod's Avatar
I have the 3" Jegs set up wish list at work.
Old 01-04-2009, 07:13 PM
grn95t/a's Avatar
courtesy of Lloyd Elliot!
http://www.jegs.com/i/JEGS/555/30662/10002/-1
http://www.jegs.com/i/Dynomax/289/24222/10002/-1
http://www.jegs.com/i/JEGS/555/30643/10002/-1
http://www.jegs.com/i/JEGS/555/30733/10002/-1
Old 01-04-2009, 07:42 PM
I think im going with the 2.5in summit setup but what exactly do i need to do because i have pacesetter lt's?
and what mufflers will be good and have clearence(everyday car)?
Old 01-04-2009, 10:10 PM
za355tx's Avatar
If I can find out if this kit will fit with LPP headers I'll buy it like 5 minutes ago. If I can do this system it would be great for the track and the dyno and just run my borla on the street.
Old 01-04-2009, 10:18 PM
tspence45's Avatar
You're good to go. As long as you've got long tubes, which the LPP's are, you can fab up an x-pipe on them. Heck, why not just sell the Borla and run some piping out back from the X. After you hear the sound of an x-pipe, you'll probably want to anyways. lol
Quick Reply: summit universal x pipe???????
