Cam question
Old 01-07-2009, 06:20 PM
maxgee's Avatar
Default Cam question
I have front mount t70 intercooled with stock cam with ls6 springs. Wondering how much more hp could be expected with a z06 cam?
Truck heads & manifold set up.
Old 01-07-2009, 06:30 PM
2002/Black/SS's Avatar
if you do all that work and just put in a z06 cam ull regret not going bigger
Old 01-07-2009, 06:34 PM
maxgee's Avatar
i hear you, but curious what the next step up cam can do from my stock, the ls6 this is so i have an idea on basic hp gains when upgrading my cam.
Old 01-07-2009, 08:31 PM
98Z28MASS's Avatar
depends on the amount of boost your running. If around 7-8 psi id say maybe 15-20 rwhp?
Old 01-07-2009, 09:10 PM
maxgee's Avatar
i'm running 8psi.
thanks for your input
Old 01-08-2009, 07:02 AM
Gingervitis Addict
slow67's Avatar
parish went from low 500s at 18 psi to right at 600rwhp with only 14 psi.... on a stock 5.3
Old 01-08-2009, 08:51 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Switching from a stock LS1 to a ZO6 will produce more horsepower and less boost as the ZO6 is less restrictive and will allow more boost into the cylinders. How much mroe horsepower it will make over the stock LS1 depends on my current mods.
Old 01-08-2009, 10:23 PM
fenix999's Avatar
Go big or go home haha j/k Seriously though, the LS6 cam is nice for what it is and its what i used for my semi-budget setup. Its also all i had at the moment and i didnt want to go through the hassle of going with a big cam and having to buy expensive *** valve springs, new pushrods etc etc etc. I dont think LS6 would be worth all the effort even though it will give you a decent power increase. It will also move your rpm range/power band up alittle bit as the Z06 cam likes more rpm's. Lemme know what you decide and ill help you out max, there are a few companies out there that have nice turbo cams...
Old 01-08-2009, 10:27 PM
fenix999's Avatar
it has a LS6 intake, #317 6.0 heads, stock cam etc, basically stock everything else plus of course the front mount turbo kit at 8psi. Power is in the 500rwhp range with this combo.
Old 01-09-2009, 12:45 PM
NastyC6's Avatar
are your ls6 heads ported?
Old 01-09-2009, 08:22 PM
maxgee's Avatar
i have 317 casting truck heads....ported.
