help please
Old 01-07-2009, 08:38 PM
95firebird5.7's Avatar
Default help please
ok so when i drive my car and i hit about 3k my car like hesitates the best way i can describe it feels like someone who cant drive stick its all jerky and what not. the car is a 96 t/a a4. my ses light is on i had it scanned and it say TPS but would that cause this? also it does not do this in park or neutral
Old 01-08-2009, 09:56 AM
In-Zane Moderator
ZONES89RS's Avatar
Well, if the TPS is sending a bad part throttle signal, the correct fuel is not going in and can cause bucking.
Old 01-08-2009, 10:31 AM
the_merv's Avatar
Maybe a short in the TPS Signal Wire.
Old 01-08-2009, 09:10 PM
now that you said that the code is tp sensor circuit low voltage p0122. how can i test for a short?
Old 01-08-2009, 10:23 PM
the_merv's Avatar
Have to get a Test Light and a Battery, and check the Wire from the Connector to the PCM Connector.
Old 01-08-2009, 10:54 PM
i know how to use a test light but what do i do with the battery?
Old 01-08-2009, 11:07 PM
the_merv's Avatar
Connect one end of the Battery to one end of the Test Light, and then the other end of the Light on one side of the Wire, and the other end of the Battery on the other side of the Wire. If it lights, then the wire is good.
I use a little 9V Battery.
Old 01-09-2009, 11:51 AM
JB_97ws6TA's Avatar
Or you could just use a multimeter on each end of the wire and check for ohms of continuity, much more accurate, should be less than 0.5 ohms
Old 01-09-2009, 02:34 PM
the_merv's Avatar
^^I dont have a multimeter, so I had to engineer my own way..lol
