define "sealed lid" and pressurization for Under car ram air please
So i've been trolling this section looking at SSRA/FTRA threads and noticed a bunch of topics on sealing the lids.
so i search for those threads and noticed 1 clear definition and about 8 vague definitions.
the 1 clear one was the OP used weatherstripping to prevent air leakage between the inside of the lid and the filter used.
the other vague definitions talked about:
sealing the ftra/ssra lips
sealing the outside of the lid?
sealing the tabs?!
I am slightly confused. Are we trying to create a Volant style closed system here or just trying to keep a barrier for the air so that any air entering the MAF housing must first pass through a filter instead of just seeping in above the filter?
someone mentioned pressurization for better results on ftra/ssra/slp cai setups. are these people just sealing the filter+lid as well or is there some other method utilized in order to turn the whole lid into a closed system?
just curious. i apologize if there was a thread already made for this specific purpose but i couldn't really find any clear answers, and only visual (torched 02 ta's video has a quick glimpse but nothing more)
sealing the tabs?!
https://ls1tech.com/forums/generatio...sults-tom.html
https://ls1tech.com/forums/drag-raci...ome-tests.html
Use weather stripping on the unside of the lid to seal the lid to the air filter, also use weather stripping to seal up the front slit where it used to take in air stock…(usually requires to stack 2-3 pieces of weather stripping on top of each other to get the 1” or so required to seal nicely…also add weather stripping to the top of the ftra to seal it to the complete lid assembly base…so everything is tight and sealed up now you will enjoy the gains…
Like chris said use weather stripping under your lid. Seal all the edges under your lid. Seal the front portion of your lid where air goes under your air box. If you click the link in my sig, you will see when i pop the hood you will see weather stripping in front of my lid. And lastly beafore you put your radiator support back on, put weather stripping on the top of the FTRA/SSRA
Why would the lid to filter need any more weather stripping than it all ready has? If unfiltered air was getting in I'm sure more weather stripping would have been included witht the after market lid. For example how SLP only gives you weaather stripping for the back side of the lid. If the lid didn't seal I would think they would have gotten complaints by now.
i saled lid refers to a WS6 style car where you put filler in between where the opening to the air lid is and the hood. this seals the lid to cooler outside air. On a camaro a FTRA or SSRA is a tunnel that goes in front of your radiator and picks up cool air from under the car. the SSRA is the best one you can get for a camaro IMHO
I have a fast toys and Ive always wondered why you wouldnt want to utlize the factory ram air scoop in the front for air from the hood as well as ftra. Seems to me the more air coming in the better. If you look at the filter over time its not like much of the other air is coming in there anyways because you can see perfect rectangles of particles on the air filter where air is directly going in from underneath. I left the front blocker off, and with my ram air air box the weatherstripping they gave with the ftra didnt even seem to be high enough on the sides to completely seal it.
This thread reminds me that I still have yet to purchase the FTRA. GP anybody???
amen. Does the super sucker have this same issue, or is their design better?
I mean, I'm sitting here thinking and trying to figure out where all you'd need to strip, and it'd almost be easier to just cover the whole thing with Duct tape. Where all are you supposed to cover, and why wasn't it done that way from the get go (or at least stripping provided)?
I understand that, but with the engine acting as a huge vaccum it doesnt seem like it would hurt at all to let even more air come in from the front. I cannot imagine the FTRA even forces enough air to "pressurize" as you are talking about it. In fact if it was pressurizing anything then it would be basically providing boost in a sense, and that definately doesnt occur. Going way up the ducting I see it as nothing more than a cold air intake, sealing off everything properly just keeps the heat from the engine from heating up the incoming air, pressurization is not the issue. IMO but what do I know? lol
check this out
might find this one interesting too i was pretty close with my 20rwhp guess in the first thread
