Injector O-ring lube?
Old 01-12-2009, 12:04 AM
01Wickedwench's Avatar
Default Injector O-ring lube?
Just recieved some 42lb green bosch/ford injectors. o-rings on the fuel rail and manifold side. And no provided lubrication with purchase. regular oil, silicone, none?
Old 01-12-2009, 12:14 AM
The Guz's Avatar
I have heard vasoline works good as well.
Old 01-12-2009, 12:37 AM
bigsticksupra's Avatar
dielectric grease works well
Old 01-12-2009, 01:06 AM
those add to the list of stuff to use, do you know what is factory recommended? Does it really matter fuel is acidic? just give me a hammer, j/k
Old 01-12-2009, 01:21 AM
WhiteRhino's Avatar
I've always used white lithium grease.
Old 01-12-2009, 01:31 AM
ColtGT4g63's Avatar
You could use whatever multi purpose grease or lube spray you have, Either will work fine.
Old 01-12-2009, 02:14 AM
FICINJECTORS's Avatar
We recommend and use dish soap. It leaves no residue when it dries.
Old 01-12-2009, 07:30 AM
crf538's Avatar
astroglide or ky all the way.
for real, i got that from some installation instructions as an o ring lube and it works great. otherwise ive put regular bearing greese on them in moderation
Old 01-12-2009, 09:23 AM
ls1king000's Avatar
I spit on it, then make em my bitchez!
Old 01-12-2009, 09:44 AM
koolaid_kid's Avatar
I don't remember where I heard it, but I use silicone grease. If you go to the hardware store, it is called "Plumber's grease". Works for all o-rings, automotive or household related.
Old 01-17-2009, 09:50 AM
BriancWS6's Avatar
I've always used a little vasoline, and some chapstick once in a pinch
Old 01-17-2009, 11:50 AM
03 BUSA's Avatar
I used the dish soap method. But have used vasoline and oil as well, but I can see why oil would be bad.
Old 01-17-2009, 12:46 PM
studderin's Avatar
any safe lube is fine, just try not to use to much its a place for gunk to stick
Old 01-19-2009, 12:51 PM
Thanks guys putting them in today, going to try one with vasoline (what my tuner recomended) and one with dish soap see which one i like.
Old 01-19-2009, 01:16 PM
sn8ke eatr's Avatar
just use regular motor oil.. thats whats reccomended
Old 01-20-2009, 12:23 AM
well, looked at a couple threads before intsall to get some pointers, and I don't want to wash the motor (at 60K) or kill O2's and plugs, going to take PCM to The HPfactory to pre/rough tune and then drive in for a pull. car is sitting fueless, fuel rail and injectors out, waiting for sunrise(some good light) to make sure everything seats right. suppose to snow too!
Old 01-20-2009, 08:36 AM
There in, started it to look for leaks and smoked like a champ. I defintly recomend removing the fuel rail, make sure the injectors are on the rail, and clips are on before you reinstall. little bit of a puzzle to put back in with them on but saves you the heart ache of makeing sure they seat the manifold. lots play if clips aren't in. oh and vasoline worked fine! soap couldn't tell the difference, buddy was lubing them while i put them on, just went with vasoline on the rest.
Old 01-20-2009, 11:09 AM
dave70's Avatar
I use gasoline. Just dab a little on the o-ring but be quick it evaporates fast!!
Old 01-20-2009, 11:29 AM
5.3LJimmy's Avatar
I always use a little auto trans fluid.
Quick Reply: Injector O-ring lube?
