Automatic Transmission - TH400 cable, which are you using...
Raven02TA
01-14-2009, 06:33 AM
like the title says, which cable are you using and how are you routing it. i keep managing to pick up a pretty long cable and after some use (say 3 months of driving it on the weekends) the cable tends to break. im sure its getting kinked up under the dash area and the center console (dont want it protruding towards my leg, it would be very annoying and not to mention unprofessional looking) but there isnt much i can to as far as moving the shifter around.... its a hurst 1/4 stick pro shifter.... if i put it too far forward it hits the dash, i pull it too far back it will hit the console and stop me from going into third, also if i raise the shifter any higher then i wont be able to route a cable to it since the dash will get in the way..... just wondering if anyone has some recommendations.
http://i81.photobucket.com/albums/j233/raven02ta/RAVEN/Picture060.jpg
pddye
01-14-2009, 09:02 AM
I'm using the stock cable, stock shifter, in the stock location. Just make a bracket out of angle iron and mount it with the bolts on the pan.
Raven02TA
01-14-2009, 10:46 PM
right, you are using the stock shifter. im not.... the button on my shifter is for the transbrake... im looking for peoples input who have the same shifter or similar and want to know how they are routing things and what length cable they are using so that its not binding up.
Shoaf85
01-15-2009, 05:37 PM
I have a B&M ratchet shifter (a lot less movement on shifts) in my Th400 setup and it came w/ a 5' cable. Sitting in the drivers seat for reference, the cable runs out of the cabin directly above the tranny then makes a long curve towrds the right and slightly down at the same time. The curve continues all the way around over the tailshaft of the tranny and then drops down on the left side to bolt into the the cable bracket! How long is your cable?
Raven02TA
01-15-2009, 11:02 PM
im running the 5' cable as well it just really seems to bind up behind the dash.... i may just have to re-do things
cabech984
06-27-2009, 02:06 PM
Im running the B&M 5' heavy duty cable. I run it out the exact same hole as the factory one, down the passenger side of the Tranny case, loop it around(in front of the trans mount) and back towards the gear selector on the TH400. I run it the exact same way B&M recommends and it works great!!
Z28/2002
06-27-2009, 05:06 PM
Same shifter I'm running and same way my cable is ran
Goldfinger911
06-29-2009, 12:44 AM
Hurst Quarter stick with the supplied bracket and cable. I have my shifter sitting on a home made 3" spacer in the rear and a 2" spacer in the front. This angle allows me to run the cable through a hole right in front of it. Not under the dash. Works great. Also it sits high enough so in park the shifter knob does not hit the dash.
SICKSS/Z28
06-29-2009, 12:53 AM
im on a spacer as well ghetto 2x4's :lol: but it works i have the quarterstick and bought a hurst cable for 50-60$
