General Maintenance & Repairs - I can't turn TCS on.
ryanater
01-19-2009, 11:35 AM
Ever since I bought my 98 WS6 the Traction Controll Off light has been on all the time. It's not the fuse. And if the switch was broken wouldn't traction control be stuck on instead of not working at all? (My ABS works fine.)
I also checked all the wheel sensors to see if they were plugged in. Is there any way to check to see if they are working?
What else could it be?
nrs2420
01-19-2009, 11:38 AM
mine would turn itself off for no reason every once in awhile. I was also having some problems with random idling issues. I replace my throttle position sensor for the RPM issue and my traction control has never turned off by itself since. Of course I turn it off right when I get in the car because I hate it. It's almost killed me a couple times.
ryanater
01-19-2009, 02:22 PM
I've never had any idling issues though. And the car isn't throwing any codes either.
nrs2420
01-19-2009, 02:26 PM
I don't know, maybe a bad traction control sensor? I don't really know how it works. Sorry
Paul87
01-19-2009, 06:02 PM
As I posted in another thread...
I had this problem for quite some time, and it freaked me out a bit. When I went in for a tire change, the problem dissapeared. Not only is it a sensor problem, but if your tires are worn out unevenly, or any other factors that would cause your wheels to not spin evenly the TCS will shut off, which is probably the case if your running your car and it shuts off during driving rather than after start-up. Same thing can happen to the ABS, it might shut off too.
If your tires are fine, then you'll have to get the sensor fixed/replaced.
ryanater
01-19-2009, 09:56 PM
Is there anyway to test the sensors?
ttranssam
01-19-2009, 10:06 PM
hey when i got my car i was working on the right side...driver...and over the hump on top of the strut there is a little single wire, check that. is a ground but the time i was working on it the same thing happened to me, once i got to where i was going i poped the hood and sure enough i ripped the wire out, i re-grounded it and my t/c worked???
ryanater
01-20-2009, 03:28 PM
If my sensor was not working or the wire wasn't grounded would the ABS still work? because my ABS is working fine.
Paul87
01-20-2009, 05:00 PM
Yes, the ABS should likely still work. It still worked for me when my TCS went out. I don't know of any way to test the sensors, I would just do what that guy did and make sure it is still grounded, and if it is, then just get it replaced.
ghardester
01-20-2009, 09:49 PM
Have you looked behind the TCS switch? Maybe a previous owner bypassed the switch and wired it so it's off all the time. The little panel that the switch is on just pops off with a little prying and goes right back on.
grey03mach1
01-21-2009, 10:58 AM
I doubt this is causing the problem but I read in my programmers manual that if the tire size is altered with a programmer TC will not work correctly. That is whats written in my diablo manual for what it is worth....
ryanater
01-21-2009, 04:58 PM
When I bought the car it was bone stock. And I already checked the switch. So the tire size hasn't been altered.
