6.0 LQ4 should I sell the 317s for 241s on N/A motor
Old 01-28-2009, 07:04 PM
95FbFormula's Avatar
Default 6.0 LQ4 should I sell the 317s for 241s on N/A motor
I picked up a very low mileage Lq4 I am using for a budget build keeping stock bottom end vrx5 cam and Ls6 intake. My question is it worth to mill the 317 heads to try to get at least 10-1 comp or sell the 317s and get 241s and mill them to get the comp higher. I know the 317s flow better but how much would I lose vs compression. I know 243 ect are better heads but my current budget wont allow it I am focusing on getting it together first. I do plan to build a 408 out of it later on so the 317s would help. So that being said if I were to run 241s or 317s milled .030 which would make more power or would they be at least even due to compression vs power also the vrx5 cam is 236/238 .601/.605 113 LSA will that even allow for me to milled the 317s .030.
Old 01-28-2009, 07:07 PM
12secSS's Avatar
I went from an 2001 LS1 long block to a 2003 LQ4 long block and lost no power. That shows you the advantage of the 317 heads with a larger bore. I would stick with the 317s.
Old 01-28-2009, 07:09 PM
13 Second Truck Club
726.0chevelle's Avatar
buy some 243s they are cheap
Old 01-28-2009, 10:18 PM
JPH
JPH's Avatar
Well, I would rather see you use the 317's (bigger int runner, exhuast port, chamber) but mill them some and use a thinner head gasket to get more SCR in the motor for your cam profile imo. The issue with this is, that with your BIG cam and milling/thinner gaskets will result in PTV clearance issues, but the 113LDA helps.
Old 01-28-2009, 11:43 PM
Ya I think I am gonna use the 317s I will probably mill them .015 and then use a cometic .040 gasket for a total of .030 off wont bump the scr up much but will help and should be able to still use my cam.
Old 01-29-2009, 12:08 AM
JPH
JPH's Avatar
Great. Squeeze as much as you can. LOL
Old 01-29-2009, 11:06 AM
Wnts2Go10O's Avatar
yes, pleeease keep the 317's... itd be a downgrade to use 241's
Old 01-29-2009, 11:32 AM
bww3588's Avatar
he said 243's not 241's
Old 01-29-2009, 11:40 AM
NemeSS's Avatar
i agree, the 241 would be a down grade.
i would use the 317 also milled .030
Quick Reply: 6.0 LQ4 should I sell the 317s for 241s on N/A motor
