What else should I replace?
Old 01-29-2009, 08:33 AM
MonmouthCtyLS7's Avatar
Default What else should I replace?
Bringing the car in this weekend for a possible lifter problem...Now while im in there what else should I upgrade/ replace...I am on a budget though.
Old 01-29-2009, 11:55 AM
ttttttttttttttttttttttttt
Old 01-29-2009, 01:25 PM
teke184's Avatar
what kind of budget??
i say stick a small cam in it.
or some budget stage 1 heads with a thinner gasket. should expect 25-30hp.
there is a thread about heads only on stock cam...pretty impressive power and basically stock driveability.
if nothing else a thinner gasket for more compression...mill the heads if possible. both to clean them up and for the compression boost.
wouldn't hurt to do the timing chain and oil pump as well.
Old 01-29-2009, 01:32 PM
Not enough of a budget right now for heads and cam work.
Old 01-29-2009, 01:34 PM
conan's Avatar
What is your budget?
Say 500 bucks
Old 01-29-2009, 01:38 PM
conan's Avatar
Originally Posted by MonmouthCtyLS7
Say 500 bucks
Lifters, gaskets and fluids will probly cost you around $300, so that doesn't leave you much room for more. Also get new lifter trays they are like $5 dollars and you need 4 of them.
Old 01-29-2009, 01:45 PM
Not counting the price of the lifters.
Old 01-29-2009, 02:05 PM
conan's Avatar
Lifters form texas speed... Comp R's $204. LS7 lifter $120... your choice. Gm head gaskets $51 each. Coolant, oil, filter, $50 (dex, and synthetic oil) $50 gm head bolts.
