tune question
tune question
and also car was tuned already but check engine light came back on cause the cat is gone can they do another tune on it to get it off so it will pass inspection thanks
^^don't the only smog in the Portland metro area?? The reason I ask is because my wife is form salem and I was going to register my car up there to do away with california's smog laws
So that same day I went to a different station and all they did was stick the rod up the exhaust pipe with no visual inspection and I passed with flying colors. I've found that some of the workers at these stations can be really cool and not give a flying shi* and others are hardcore
Use a spark plug non-fouler HELP section 42002 (or whatever one is the non tapered version) I believe is the part number. It'll stuck the sensor out of the exhaust stream just enough to get the voltage to change from that of the front two and kick off the SES/CEL
That won't fix your visual inspection though haha
