E-brake and narrowed rear ends????
Old 01-30-2009, 05:09 PM
SIC LSX's Avatar
Default E-brake and narrowed rear ends????
Im going to be looking to get a narrowed rear end sooon and how far can you go without messing with the E-brake? I was wanting to go 3" on each side, but was told i would have to loose my E-brake and i cant do that im a M6. I was also told you can keep you e-brake. You just have to make a bracket to hold the cable? I may just get 2.5". any info will help thanx
Old 01-30-2009, 09:40 PM
SIC LSX's Avatar
anyone???
Old 01-30-2009, 09:56 PM
SmokedOutZ28's Avatar
I was told 3'' and everything will still be ok. Mine will be cut 2-1/2 and everything will stay the same I'm just awaiting it's arrival for installation.
Old 02-01-2009, 09:02 AM
SIC LSX's Avatar
i was told 3" you will have trouble with the ebrake. So i was wanting to no if ya could mod something up to keep it
Old 03-13-2009, 05:11 PM
BUMP
I'm narrowed 2'' and it seems my brake bracket hits the rotor any body know how to remedy this issue? Without making a new bracket, Gotta have the bracket no way around it.
guess the info wasn't as accurate as I thought it would be.
Old 03-13-2009, 09:52 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
i can retain the e-brake on any narrowed housing up to 3 inches... maybe more with the narrowed lca brackets. we manufacture our own cable bracketry and is included with all the rearends using the stock brakes. best thing of all... none of it is extra charge.
Old 03-13-2009, 09:57 PM
How much for 2 brackets for a narrowed rear 2'' each side? S60 BTW
I tried using my stock brackets and they interfer with the rotor/caliper mount so I cannot run it without modifing it. I would rather have something that is a sure thing and will look good rather then a hacked up welded up stock bracket.
Old 03-14-2009, 03:29 PM
gorace's Avatar
I just cut the orginal bracket and welded it to the lca bracket pretty easy just make sure to use a gusset to add extra support i'm narrowed 3" also
Old 03-14-2009, 03:31 PM
gorace's Avatar
You're really just using the eye part of the mount its about 1" long and you weld it at a angle, you get rid of the rest.
Old 03-14-2009, 07:34 PM
Yeah Thats what will need to be done. Just got off the phone with eric and gonna have to make something here and have it welded.
Old 03-19-2009, 04:55 PM
93_355bird's Avatar
i think its 3 inches total and youll be fine (1.5 inches perside).
Old 06-24-2009, 04:47 PM
SIC LSX's Avatar
Thanks midwest for adding this. Cant wait to order mine! Saving up now!
This is on my friend lrry93 so you can easily hook ebrake back up with a 3" narrowed on each side. So i wont have to fab somthing up to make it work when i order it 8)
Quick Reply: E-brake and narrowed rear ends????
