Sponsored by: DashLynx
Headlight Polishing Kits ? Which one ?
Old 01-31-2009, 02:46 PM
SS DNA's Avatar
Question Headlight Polishing Kits ? Which one ?
Anyone have experience with those Headlight Polishing kits ??
I have a set of Headlights that I want to restore.
So far I been told to try the Novus Spa kit, I heard nothing but good things about it.
I just tried some Meguairs liquids to restore the Headlights along with a Power Ball but I dont really see much improvement.
Any suggestions ?
Thanks
Old 01-31-2009, 02:59 PM
hlaalu's Avatar
wet sand them first. then apply the polish and restore with a buffer.
Old 01-31-2009, 03:02 PM
Customizing Director
MadIceV8's Avatar
I've always had good success wet sanding them lightly and then using a 3M rubbing compound on a buffer.
Old 01-31-2009, 04:02 PM
Counted Out's Avatar
Yeah, wetsanding is the way to go. The Headlight Restoration kits even say something like "For some cases, wetsanding with 2000 grit will be necessary", and most of the time it is.
Then just polish them up.
Old 01-31-2009, 04:32 PM
wannafbody's Avatar
I saw some pics of a set of lights done with the kit they sell at WalMart. Needless to say I was shocked at how good they turned out and it only cost $20.
Old 01-31-2009, 08:55 PM
TUCKZ28SS's Avatar
i used wet sand (1000-2000 grit) then buffed with meguires plastx and they arent like new, but a whole lot better. Also buy some headlight sealant from a good body shop supply store or they will fade again.
Old 02-01-2009, 12:48 AM
SS DNA's Avatar
What is this sealant you talk about ?
Old 02-04-2009, 03:09 PM
98redM6's Avatar
I believe a sealant isn't necessary if you purchase the novus spa kit. One of the steps involves applying something to protect them from future fading. I've read of some people applying high temp clear to their headlights, but I'm sure better options are available.
Old 02-04-2009, 03:17 PM
dorifto83's Avatar
I used the 3m kit from autozone, 20 bucks and did a good job cleaning them up.
Old 02-04-2009, 08:36 PM
black00ssFL's Avatar
https://ls1tech.com/forums/appearanc...ess-story.html
Quick Reply: Headlight Polishing Kits ? Which one ?
