procharger HELP!!!!
procharger HELP!!!!
Hey everyone i have some questions to ask im thanking about geting a procharger.... so what all will i have to do to put it on and can a stock lt1 hold 12-15psi throw it just get back with me thanks..
11Second Club
I don't know much about LT1s, but I would say no, it can't handle 12-15psi. LS1s usually won't take more than 8psi based on what I read on here. As far as what all you'll have to do... The majority of it will be in the kit (blower, piping, intercooler(s), injectors, belts, pulleys, relocation brackets, new fan shroud, etc, etc). However, you will probably want to get a new fuel pump (or two) instead of using the boost-a-pump that will most likely come with the kit. You might want bigger injectors, too... and possibly a front-mounted fuel pressure regulator.
LS1TECH Sponsor
Jon
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
[QUOTE=moehorsepower;10976858]I would only hit 9 lbs on some occasion's. But usually made 8 other times, the car only had 9,000 miles so i knew the engine wasnt worn by any means, but like I said it was scary still.
it has everthing but a few pipes to the intercooler and fms or wat ever it is and the injectors
