procharger HELP!!!!
Old Feb 2, 2009 | 11:57 AM
cumminsman202's Avatar
Default procharger HELP!!!!
Hey everyone i have some questions to ask im thanking about geting a procharger.... so what all will i have to do to put it on and can a stock lt1 hold 12-15psi throw it just get back with me thanks..
Old Feb 2, 2009 | 12:46 PM
Gauge's Avatar
11Second Club
I don't know much about LT1s, but I would say no, it can't handle 12-15psi. LS1s usually won't take more than 8psi based on what I read on here. As far as what all you'll have to do... The majority of it will be in the kit (blower, piping, intercooler(s), injectors, belts, pulleys, relocation brackets, new fan shroud, etc, etc). However, you will probably want to get a new fuel pump (or two) instead of using the boost-a-pump that will most likely come with the kit. You might want bigger injectors, too... and possibly a front-mounted fuel pressure regulator.
Old Feb 2, 2009 | 02:56 PM
moehorsepower's Avatar
All I can tell you is you better dig deep into your 401K, It takes a lot more than just bolting up the procharger, and NO you cannot run 12-15 lbs on a stock motor, or yes you can.....maybe once....
Old Feb 2, 2009 | 03:30 PM
Gauge's Avatar
11Second Club
Oh, and, of course, you'll need a tune to go with all that. Expect to spend around $8,000 and you might not be disappointed with the final price tag.
Old Feb 2, 2009 | 04:46 PM
ok thanks everbody i was just woundering couse i found a procharger and a cam for 1200.00 shipped so i didnt know but thanks everyone
Old Feb 2, 2009 | 05:29 PM
MadIceV8's Avatar
Customizing Director
Keep boost at or under 8 and you might be fine. But you'll still have to put money into the trans, rear end, tune, ect...
Old Feb 2, 2009 | 07:13 PM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
I would be interested in what you get for 1200, sounds like it may be missing some pieces. Like said above, 7-8 psi on stock engine would be the limit.
Jon
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Feb 2, 2009 | 07:21 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Get a new opti spark while you are at it.
Old Feb 2, 2009 | 07:22 PM
4SFEDSS's Avatar
I ran about 8-9 lbs on mine with no problems, but your still taking a chance. Its kinda scary. Just make sure to keep money aside incase something does happen.
Old Feb 2, 2009 | 07:34 PM
Captain_Stabbin's Avatar
it would definitely make more power, but of course the question would be, for how long would it hold it, its better to just save ur money and build the motor...
Old Feb 3, 2009 | 06:21 AM
[QUOTE=4SFEDSS;10974051]I ran about 8-9 lbs on mine
I hope you are playing I got big ***** when you are hitting the 9lb mark lol.....
Old Feb 3, 2009 | 07:31 AM
ls1290's Avatar
Dumb Ass Vette Moderator
For that price, it can only be the head unit with no bracket, plumbing, IC, clamps, hoses, etc. I would even guess the head unit would not be 100% either. I would pass up that deal.
Old Feb 3, 2009 | 07:37 AM
WAHUSKER's Avatar
Good advice, you usually get what you pay for with forced induction.
Old Feb 3, 2009 | 07:47 AM
4SFEDSS's Avatar
[QUOTE=moehorsepower;10976858]
I would only hit 9 lbs on some occasion's. But usually made 8 other times, the car only had 9,000 miles so i knew the engine wasnt worn by any means, but like I said it was scary still.
Old Feb 4, 2009 | 08:21 PM
it has everthing but a few pipes to the intercooler and fms or wat ever it is and the injectors
