lt1 plug wires.....need help
ok i bought msd 8.5's installed them a week later i burnt one on the header and the other one rubed on the power steering pully... these wires fit like **** not to mention the way you have to run them on these cars... anyone have some pointers im goin to get a new set and dont want to have the same problem again?
oh and i made sure there was enough clearence around things and they must of moved, theres like no slack in these wires to play with.....
Back when I had a Lt1 I had the same problem. Auto Zone sold spark plug wire wrap and that did it for me. It is kinda pricey but I got really sick of burning wires. Those wires ARE A BITCH TO INSTALL!!!!! But try it it worked for about 20k then I sold the car. Probly still working out with the new owner. Its like header wrap only for wires.
To say that LT1 plug wires are are a bitch to install is an understatement. But you thrash and get it done. Thunder Racing has fire sleeves and over the cover kits which ONLY work properly if you have headers. You said header, but if you really mean exhaust manifold that is stock this is not the answer. With headers, this is by far the best way to go as it routes the wires straight up over the valve covers. I did an MSD Opti Spark cap, plugs, wires, spent the better part of two days dorking with it but it runs like a deer and has done so for two years. Scroll through the link and put it to bed
http://www.thunderracing.com/catalog...vid=4&pcid=198
