Rear end looks weird...
Well it was actually a warmer day here and I was outside having a smoke and i was standning directly behind my ws6 and noticed that my left back tire shows about an inch more tire than the right, and the right back tire is barely visible...could this be my bumper or the frame? the tires aline with the body fine on the front part of the wheel well and it drives fine, it just bothers me when I look at it and I cant figure it out... and suggestions?
rear end looks weird
its not lowered, its at its stock height. is the adjustable panhard bar hard to instal and is it visible from looking at the car once installed?
all our cars are about half an inch lower on the passenger rear side... it is made that way to compensate for the drivers weight. We had a nice discussion on that a month or so ago... but you should still check the panhard bar just to be sure
Here is an example of one of the prior posts on the subject.
https://ls1tech.com/forums/suspensio...iver-side.html
plenty more if you search
To the OP- I am a little unclear what you are describing. Is one side higher than the other or does the wheel set out farther than the other on one side.
Higher= deal with it or maybe hose mod on the high side.
Side 2 side= adjustable PHB like Keliente said.
From what is being described, you should be able to correct it with an adjustable PHB as stated before. It won't be any more noticeable than your stock bar and is very is to install and adjust. My suggestion would be a double adjustable as the singles sometimes don't give you enough adjustment (depends on Manufacturing Co).
