how much power should i make
how much HP should i make with this setup.2000 camaro- ss hood, texas speed lid, k&n filter, p&p tb, torquer 2 cam 232/234 dur. 595.598 112 lsa, 918 push rods, comp cam lifters, comp cam 625. springs, bbk inake, ls6 oil pump, ls2 timing chain set, ebay long tubes headers, and free mods, 22-28 torque converter. what do you think it will run in a 1/4
Stock heads through an aftermarket converter on an A4....I would guess in the relm of 390~400rwhp. Depending on the weight of the car, what you do to prep for the track, etc. - you could be anywhere from a mid 12 to a high 10 second car. In factory trim with drag radials, I'd say 12.2's.
Formerly darynC-10/23/10
the scoop on the ss hood will actually rob you of a tenth or 2. ben there done that.
as for mods i would say 12.278 @111.4 depending on driver and what your car is shifting at- that is on drag radials/slicks
With that setup, a little weight reduction (spare tire, seats, not a full tank of gas, etc.), unhook the front sway bar, maybe some lightweight wheels (draglites, bogarts, etc. - you know, the ones with skinnies). That'll put you into the 11's.
