Synergy 2 step question
Old 02-18-2009, 05:52 PM
98Camarod's Avatar
Default Synergy 2 step question
I can't seem to find the installation instructions for a 98 auto. Anyone have these handy or know where I can find them? Their website has been closed so thats out of the question. I found instructions that red93 had for a 99-02, but those are different.
Old 02-18-2009, 08:26 PM
Avengeance's Avatar
Call Rick directly.... (510) 796-3749
Im sure he'd be willing to help you out.
Old 02-19-2009, 12:32 AM
tha joker's Avatar
agreed just call rick he will be more than happy to help ya out
Old 02-19-2009, 01:09 AM
kp
kp's Avatar
This is what was sent with mine a few years ago.
Old 02-19-2009, 04:57 AM
98Camarod's Avatar
Thanks kp! I don't have a transbrake, so should I route it to the brake light switch and you wouldn't happen to know where that is would you?
Old 02-19-2009, 07:25 AM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
crap! i forgot all about sending you the instructions! i will scan mine tonight when i get home. pm me about 4pm or so and remind me.
Old 02-19-2009, 07:41 AM
GTFORMULA's Avatar
Is Synergy still open ? Im looking to buy a 2 step and the Lingenfelter one stays on all the time if you have a 6speed. So everytime you push in the clutch it hits the 2 step as per other threads.
Old 02-19-2009, 08:53 AM
Blackbird's Avatar
yes, still open and going strong.
Old 02-19-2009, 09:24 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Moving to better section.
Old 02-20-2009, 06:08 AM
GTFORMULA's Avatar
They are not sponsors anymore ? They were not on the list when I looked.
Old 02-20-2009, 06:59 AM
red83's Avatar
you can look up rick@synergy and it says banned.
he is a real nice guy. so dont let the "banned" come off as a bad term. it could have been something a simple as sponsorship dues or a simple disagreement.
Old 02-20-2009, 09:28 AM
Blackbird's Avatar
yah, he dropped sponsership a long time ago.
Old 02-20-2009, 09:43 AM
RZRSEDGE's Avatar
You could just put a flip switch in line so it only activates when you want it to while the clutch is in.
Old 02-20-2009, 10:50 AM
GTFORMULA's Avatar
It would be hard to flip a switch when Im leaving @ 6600 rpm and on 2 nitrous kits going mid nines. I wish Harlin was still making them.
Old 02-21-2009, 08:22 PM
LS1Tech Sponsor
Jason Haines @ LPE's Avatar
Default Lingenfelter 2-step "always on"
Sorry to continue this topic that isn't really part of the original thread but...
Regarding the Lingenfelter 2-step being active on every shift on a manual transmission car, it depends on how you choose to activate it.
If you are using a clutch switch you can also use our MPH activated switch (STOV-001) to disable the 2-step once you are moving.
We also have several customers that allow the 2-step to trigger during the shifts to use it as an engine torque cut to help shifts and allow them to no lift shift.
Old 02-21-2009, 08:29 PM
98Camarod's Avatar
What about a brake light switch for the automatic guys?
Old 02-21-2009, 08:36 PM
LS1Tech Sponsor
Default Brake light switch
We have several automatic customers that have the 2-step wired to the brake light switch (with an inline switch so that it can be disabled under normal driving).
I assume the Synergy unit could also be wired to the brake light switch.
Old 02-23-2009, 01:01 PM
RZRSEDGE's Avatar
I believe the 6 speed guys use them so you're not tagging the rev limiter on the power shift. That and you didn't clarify you were talking solely about track use. Because of those 2 things I thought you were talking about driving on the street and being on the 2 step when you mashed the clutch. Still easily fixed with a momentary switch like used for a trans brake in conjunction with the clutch operation.
To the OP, mine is setup off the brake light switch, found under the dash above the brake pedal, and a window switch with WOT detect. Works like a charm. Brake pressed, foot to the floor = 2 step active. Off brake and it's go time.
Last edited by RZRSEDGE; 02-23-2009 at 01:48 PM. Reason: Brake light switch location
Old 02-24-2009, 06:57 PM
98Camarod's Avatar
That makes sense. Not really too sure how to wire that up though. Any pointers?
Old 02-24-2009, 07:13 PM
red83's Avatar
i thought you was selling it? i will try to send the instructions w/ my wife tommorrow to scan. i still havent fixed my scanner.
did it not come w/ instructions?
Quick Reply: Synergy 2 step question
