Good with fiberglass? Let's talk..
Well, in the spirit of being a little creative and different, I am looking for someone who is good with fiberglass. My tired 1995 A4 console is screaming at me. I would like to fiberglass over my crummy console lid (no more lid). I would also like my mounting points re-inforced. Once everything has been nicely fiberglassed over, it will be taken to my local upholstry shop. I am told that some high end audio installers are a good place to search. Input anyone?
Sounds like some "Unique Whips" type ****. That's is ALOTTTTT of work. I had some buddys a few years ago that owned a stereo shop, and being that I do body work for a living they thought I would be a good canidate to fiberglass the cargo area of a mid '90's Suburban where they had built a board with mounting spots for 4 15" subs and then smooth it all out and blend it in with the rest of the interior. It was horriable.
I know there has to be someone out there in LS1TECH land with plenty of fiberglass materials just sitting there, collecting dust.. LOL. Instead of buying a new console for $150 bux, I would rather spend that money fixing up the one I have.
I will post in the audio section as well. It would be a nice little project (it shouldn't take more than 4 - 5 hours to fiberglass it over and get it back to me). Even if someone took their time with it and worked on it here and there, it would be a nice little weekend project.. LOL. Anyone interested in making a little extra money on the side?
It shouldn't even be near $150 but I am being a little generous because I need this finished in about 3 weeks. The grey'd out areas are the parts that I need fiberglass work. The arm rest door will be removed and basically all I need is to have it fiberglassed over (effectively deleting my problematic arm rest door). The front mounting point is cracked so a little fiberglass there would repair the mount. Very basic stuff for a person who works with fiberglass. For me, hard as heck because I have NO fiberglassing experience.
hmmmm... not the feedback I was hoping for. I am on borrowed time until my car is delivered back to me in a few weeks. Looks like I might have to come up with a different solution.
So your problem is that the front mounting point is cracked? Sand the area a little bit with like some 80 or 120 grit sand paper and poop some JB weld on it. That should hold it..... for a while at least.
Same thing I did post about firberglass on dash cover I think about. No one able answer..One day i will try do that...
Link here>
Fiberglass on dash
Link here>
Fiberglass on dash
Moderator
I have done a little with 'glass, no pro. Number
one recommendation is to skip the Wal-Mart /
AutoZone stuff and go for the System West
real epoxy that you'll find at marine stores. Way
tougher, better adhesion, better work time etc.
compared to the polystyrene resin in the Bondo
kits.
As far as making it look like it matches, you're on
your own there.
If it's a broken plastic problem, you may be able
to solvent-weld it (multipurpose PVC/CPVC/ABS
cement) or fusion-weld it (Harbor Freight plastic
welding system). These could be better than an
applique patch.
kits.
your own there.
applique patch.
