TCI vs Yank
Old 02-24-2009, 08:04 AM
blackhawk0251's Avatar
Default TCI vs Yank
I dont mean to start a "Battle of the stalls" thread but this is kind of a serious question. Ive only heard of TCI a few times because all ive heard about was Yank stalls. I hear they have really good lockup which makes them a higher quality stall. I need a stall for a new built transmission I am getting for my car. I can get a TCI 3200 for 300 bucks...what my question to you is, is it worth it as far as quality/money? My car is a daily driven street car.
Old 02-24-2009, 08:24 AM
cookba's Avatar
if your spending the money for a new built tranny, you might as well do it once and do it right with a Yank. search on here and you'll see allot of complaints about TCI, there flexplates are good though
Old 02-24-2009, 08:26 AM
this must be why I havent heard much about them. Ive always heard to go with a Yank stall... Im honestly looking for a used stall because of my budget, as long as its clean I dont mind
Old 02-24-2009, 08:35 AM
TurboAv's Avatar
Give FTI a call. They are running a special right now. Regardless of who you choose to go with, don't cheap out with a TCI. Used is a big risk on a brand new transmission. You could totally ruin it if there is junk in the converter. If you do go used I would get it cut apart and cleaned.
Old 02-24-2009, 10:52 AM
8ByGoat's Avatar
I have had both.
Not even close go with the Yank.
Old 02-24-2009, 11:06 AM
Circle-D's Avatar
You are comparing two very different converters. The TCI probably uses a stock front cover and an adapter to convert it over to the LS1 bolt pattern. Meaning it uses a lock up clutch out of a stock FWD converter. Where as the Yank will use a billet front cover and a much larger clutch. Plus you add in the factor that it is used, it gets very scary. I strongly suggest to get the billet front converter if you are using the 245MM converter. I also suggest getting a Circle D Billet version, but I am a little biased. I also offer a 278MM - 3000-3200 - non billet converter, but it uses the full size RWD lock up clutch. It will save you few bucks over the billet version and still be very strong. Just an FYI.
Chris
Old 02-24-2009, 11:36 AM
Yank's Avatar
Give Dave or Mike a call at 775 826 9955 or go to or site www.converter.cc
We would like to talk to you.
Old 02-24-2009, 12:45 PM
StealthFormula's Avatar
There is no comparison between the two. I would spend more money and do it right by running a Yank or Circle D. You can get a used Yank on the board for a decent price.
Old 02-24-2009, 12:59 PM
Detoxx03's Avatar
Do it right and get the Yank
Old 02-24-2009, 01:22 PM
daniel6718's Avatar
there no comparison...yank is better in every aspect
Old 02-24-2009, 02:02 PM
Will do, thankyou.
Old 02-24-2009, 07:53 PM
heymoej's Avatar
go yank & dont look back..............
Old 02-24-2009, 09:31 PM
caldercay's Avatar
Originally Posted by blackhawk0251
I dont mean
Yank or Circle D
Old 02-24-2009, 09:55 PM
Pontiacerator
RevGTO's Avatar
The concern with TCI is the weak factory lock-up clutch disintegrating and taking out your trans.
That being said, I ran a TCI 3000 for three years daily driving with many trips to the track and loved it. I replaced it with a Yank SS3600 and although it will flash 500rpm higher, neither my 60', my ET, nor MPH improved with the Yank. Sure, it's a better built converter, but the lack of performance gain was a disappointment.
I believe that my Transgo shift kit with PWM elimination was the key to longevity with the TCI.
Old 02-24-2009, 10:09 PM
StreetSilverado's Avatar
I'm with a PTC 4000 right now, and I wished I had more money at the time to go with a Circle D. I regret it, then again it does get me around a lot better than the stock one. I'm hoping to get a built transmission and Circle D from a friend here in a couple of days.
Whatever you do, don't go cheap with a converter. I regret it everytime I step on the gas
Old 02-26-2009, 11:13 AM
Spellbound's Avatar
I've had good experiences with both TCI and Yank. The Yank was much prettier to look at, thats for sure.
Performance wise, very little difference.
TCI 4400: 11.36@120 1.53 60'
Yank PT4000: 11.31@120 1.58 60'
FWIW
Old 02-26-2009, 11:41 AM
Droptopws6's Avatar
I would Yank it for sure, I yanked mine. I just love Yanking it...
Old 02-26-2009, 11:50 AM
epox4life's Avatar
If you go TCI be careful of it's lockup clutch. Mine lasted about 6 months daily driver, then the lockup clutch started slipping and making a grinding noise.
Old 02-26-2009, 06:26 PM
02 BLK WS6's Avatar
Yank, Vig/PI, or Circle D
I am pretty certain the above mentioned converters are the best on the market.
Old 03-01-2009, 09:27 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
Give Tracey a call at Rev Extreme.He has a few yanks that have been traded in by customers wanting more performance that he will probably make you a deal on or I can build you one of our billet converters.Go to our website and look at the SRL page.
Greg
1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Quick Reply: TCI vs Yank
