fuel pump bad ???
fuel pump bad ???
2000 trans am,,,,,,, the cars starts,, idles anywhere from 100 to 800 rpm, then eventually stalls. I hooked up a pressure gauge and it was bouncing around between like 15 and 40. I'm thinking the fuel pump. Would this be a good choice......http://store.summitracing.com/partde...5&autoview=sku
not to hi-jack but the problem I am having is that it always bouces back to E then to wherever the fuel should be then to E again and sometimes it stays there..whats the problem???
I think you will be more happy with a Racetronix pump, it's a more complete kit and lets you keep your stock venturi function.
You can buy directly from us here :
http://www.racetronix.biz/itemdesc.a...PA-001&eq=&Tp=
Or you can use any dealer that carries Racetronix products.
So unless there is a gaping hole in the top of your gas tank (in which case you wouldn't probably be overcome by fuel vapors before you could start cutting anyway lol) there is no chance of anything blowing up.
11Second Club
I Dremel'd mine, and I could see an avalanche of sparks cascading across the top of the gas tank. It was very unnerving. I'm still here, though, and so is the car!
Just to be sure before I put the new Racetronix in,,,,,, Are the wires and wiring harness clips really submerged in the gasoline?, or did some sort of surrounding fall into the tank when I removed the factory setup. Also, will I see any difference in performance with the Racetronix pump?? I only ordered the pump,, not the wiring harness that was like 50 bucks. Do I need that?
Yes the in tank wiring harness is submerged in gasoline. That's why it needs to be made from special wires and connectors.
