is there a way you can pull the pulley off of the waterpump?
im fixing to powdercoat all my pulleys and waterpump,is there a way to pull that pulley?its a 2002 ls1.and the engine is on the stand.
i removed the pump and taped the pulley off real good and painted mine. i sprayed a lil behind the pulley and cant see where the paint ends or any unpainted areas
I got the same problem.. I have my timing cover and valve covers power coated black hammertone... I wanted to do the water pump but I dont even want to risk it usually the temps that are used to melt the coating is between 300-500 degrees.. the pully needs to be pressed on and off.. But I just decited to rattle can the pump black.. I think it should look fine..
But here are some before and after pics..
sorry but they are tiny
