17x9.5 with 54mm or 56mm backspacing?? On a camaro?
Old 02-25-2009, 08:51 AM
nhra_crazy's Avatar
Default 17x9.5 with 54mm or 56mm backspacing?? On a camaro?
I am looking to order some wheels here soon for my 98z and am looking to do 17x9.5 all around.. I found some with 56mm backspacing and 54mm. Which one is gonna look better or isnt it gonna matter.. I havent been able to find and pics of this size on the rears of camaros. I am looking towards the new vette wheels with lip.. Anyone have any pics?? Thanks
Old 02-25-2009, 01:56 PM
nhra_crazy's Avatar
Anyone?? These are what im looking at getting 17x9.5 54mm all the way around.. And i just want to make sure they wont look crappy on the rear with that size??
Old 02-25-2009, 02:13 PM
BOTTLEFEDLS1Z's Avatar
Do not get the 36mm offset for the rears. They will stick out. I'm running a 17x11 with a 50mm offset and it looks perfect.
There is a sticky on wheels offsets and backspacing in the wheels section.
EDIT***https://ls1tech.com/forums/wheels-ti...must-read.html
Old 02-25-2009, 02:42 PM
nhra_crazy's Avatar
I would be buying the 17x9.5 54mm for the rear.. Thats what im wandering how they will look..
Old 02-25-2009, 02:50 PM
RSTEWART's Avatar
17x9.5 & a 54m offset will look fine! Ideally anywheres from a 46mm--54mm is best, but you have to remember tire size is extremely inportant, i suggest a 275/40/17 is your best fit on all 4 corners!!
A real decent tire in that size is the general exclaim uhp& can be had @ tire rack for $120 !
Old 02-25-2009, 02:53 PM
You'll be fine then. Fit like stock
Old 02-25-2009, 03:43 PM
Customizing Director
MadIceV8's Avatar
Go with the 54mm. I'd personally go with a 50-48mm if available.
Old 02-25-2009, 05:30 PM
nhra_crazy's Avatar
Thanks for all the info guys... I just didnt want to rear wheels looking shitty as in sitting in to far or sitting out to far..
Old 03-01-2009, 01:39 AM
topdj-com's Avatar
ebay Item number: 220368017934 any know why these seem too cheap
Old 03-07-2009, 01:19 AM
topdj-com's Avatar
so has anyone bought these ? are they heavy?
Old 03-07-2009, 01:28 AM
devildog's Avatar
cheap (as in crappy made) replicals? need more info on these fo sho...
cause im with this dude here...
Old 03-07-2009, 12:20 PM
topdj-com's Avatar
I like the gun metal version but if they are hard to balance junk I don't want them.
I don't see how they could be built in the same plant as the Original equipment plant.
Are they gravity cast or pressure cast too bad the seller doesn't state it
Old 03-07-2009, 04:58 PM
Bullet95z28's Avatar
id run a 285 on the back but thats just me, i had 285 on a 9" wide firehawk, it looked and rode great. Those wheels are nice by the way
Quick Reply: 17x9.5 with 54mm or 56mm backspacing?? On a camaro?
