head/cam
Old 02-25-2009, 10:47 PM
cptncdy's Avatar
Default head/cam
i am in the process of buying some parts to do a head/cam install and i want to make sure that i am not forgetting anything.
so far on my list is:
TSP torquer v.2
PRC 220cc 5.3L Stage 2.5 CNC Ported Heads
LS2 timing set
LS6 ported oil pump
LS7 lifters
bolts and gaskets
I am buying the H/C in a package deal so it will come with the springs, pushrods, etc..
Old 02-25-2009, 10:50 PM
'02 WS6's Avatar
Don't forget the crank bolt lol. Now would be a good time to do a U/D pulley if you haven't already. Other than that from what I see you're all set.
Old 02-25-2009, 10:56 PM
cptncdy's Avatar
haha yeah i have the crank bolt on the list too. i have considered getting an U/D pulley but decided that i am going to wait on that because i am already spending enough money as it is
Old 02-25-2009, 11:14 PM
'02 WS6's Avatar
I hear you on the funds. H/C swap can climb up in $$ in a hurry.
That's the same combo to a Tee, that I was gonna go with, before I snagged some GTP stage 2+. Post up your #'s in the dyno section when your done, and enjoy the permanent grin you're going to have from that combo.
Good luck
Old 02-25-2009, 11:25 PM
cptncdy's Avatar
will do!
Old 02-26-2009, 08:59 AM
jasycz28's Avatar
I was looking at something similar to this. What numbers do you think you can pull with this set up? I want something to put me mid to low 11's and hopefuly 10's on 100 or 150 shot. But for the money I think you can't beat this setup.
Old 02-26-2009, 09:25 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Don't forget the new oil pump o-ring! Most of the time, I recommend replacing the lifter trays while you're there too. They're too inexpensive and crack too easily not to replace them.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-26-2009, 02:07 PM
cptncdy's Avatar
Originally Posted by jasycz28
I was looking at something similar to this. What numbers do you think you can pull with this set up? I want something to put me mid to low 11's and hopefuly 10's on 100 or 150 shot. But for the money I think you can't be this type of a setup.
to tell you the truth i have no idea but i would imagine somewhere in the 11's cosidering that i ran a 12.7 with the mods in my sig.
do yall sell the lifter trays on your site? i am having trouble locating them
Old 02-26-2009, 04:47 PM
JRC2000SS's Avatar
dude i would do the LS6 2.5's. right now i have the PRC 5.3 2.5's, Torquer 3, LS6 Intake, and I only put down 415/390. i wish i would have jus bought the LS6 2.5's
Old 02-26-2009, 05:48 PM
cptncdy's Avatar
those numbers seem a little low..what other mods do you have?
Old 02-26-2009, 08:02 PM
RedRallyeZ's Avatar
be careful with the UD pulley, i picked one out originally but with my stall, and gears i couldnt keep that combo off the rev limiter. i didnt see if you had any gears but thats just a problem i ran into with my 3500 rpm stall.
also, those numbers are in line for a H/C auto with that combo. Ive got 2.5 5.3's and a torquer 3 with all the regular goodies, and i put down 384/355, that was through an unlocked convertor and a flowmaster catback, but my torque curve is flat and pulls at any rpm. so dont get caught up in a numbers game. a GOOD tuner can extract good numbers from any combo, but dont go down the road of making a torque curve look like mount everest for the sake of peak numbers.
and if all else fails, call TSP and ask what they recomend. thats what i did and i originally was gonna get teh LS6's
Old 02-26-2009, 08:20 PM
cptncdy's Avatar
thanks for the advice..i have been talking off and on with TSP for about a month. i am confident that they are pointing me in the right direction.
Old 02-27-2009, 12:07 AM
JRC2000SS's Avatar
dont look at numbers? numbers mean alot when u spend 1,600 on parts and the port job isnt wat it should be. i know the numbers sound low and we here in san antonio have one of the best tuners in town w/o a question. i even put the #30 injectors cuz it was leaning out and still no change in the numbers. im very upset with the package i got and i dont want someone else to feel like they got taken like i did.
unless u have a money tree in ur backyard... u should share with the rest of us.
Old 02-27-2009, 12:30 AM
RedRallyeZ's Avatar
all im saying is that those numbers are in line with the rest of the ones ive seen with that combo, little lower than some, little higher than others.
and if you are spending $1600 in parts the LAST thing id do is define success by a single number. i love my setup, and would never trade it for a huge cam that has to rev to 4500 before it sees numbers, even if they are higher than my peak
Old 02-27-2009, 12:18 PM
SweeTbone's Avatar
What kind of times you running? I only have a Ported FAST 90 and UDP put down 30 more HP. Don't expect to buy an "off the shelf" H/C package and put down 500 at the rear wheels. Add a FAST 92 and pulley to your setup and you'll break 450 for sure. I might have broke it but my factory clutch was slipping after the first pull and I was going through a Catted Y at the time.
Old 02-27-2009, 12:20 PM
sanya_kim's Avatar
I just installed my torquer v2 with 243 heads.
I was hearing loud sewing machine sounds...
after calling around, I found out that pushrods you get from the package is too small...
they suggest you upgrade to 7.42 pushrods to eliminate the sounds...
I'm not too sure if it will affect your performance though.
just my .02
Old 02-27-2009, 04:50 PM
JRC2000SS's Avatar
i have yet to take it to the track and i wasnt expecting 500rwhp either. but i do think that 420ish would be reasonable. there are guys in my area using stock 241's makin more power than me and theyre using either ms3, ms4, or tq3 cams. theyre making in the range of 440-460 with non-ported LS6 intakes. im sure its possible that i ended up with a bad port job but i should be over the 420 hump for power...
so explain how 241's bone stock or mildly milled will make more power than a set of 2.5's?
Old 02-28-2009, 01:12 AM
cptncdy's Avatar
well i just bit the bullet and ordered everything. now it just needs to hurry up and get here so i can install it
Old 03-30-2009, 11:41 PM
cptncdy's Avatar
i finally got everything installed and tuned today. the car made 420rwhp and 383rwtq on the dyno jet at HPE. so far i am very happy with my setup but i haven't got to drive it that much.
Old 03-31-2009, 05:46 AM
djfury05's Avatar
any before numbers? did you end up replacing the lifter trays? if so, where'd you get them?
