Lonnies Performance double pumper kit
Old 02-26-2009, 06:41 PM
T-Bones Goat's Avatar
Default Lonnies Performance double pumper kit
Guys, just wanted to let everyone know that I have been running Lonnies double pumper kit for over a year now and it has worked great making over 900rwhp with a Procharger. I just ordered a new set of 96lb injectors and an AEM driver for the Goat from Lonnie as well. He is a top notch dealer and really knows his stuff. I would recommend his products to anyone. Travis
Old 02-26-2009, 07:53 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Thanks for the compliments & glad it is working well for you.
Now go out & break 1000rwhp since you now have more fuel injector.
Old 02-26-2009, 08:55 PM
405HP_Z06's Avatar
Another for Lonnie, a super vendor.
Old 02-27-2009, 06:21 AM
jmdgto's Avatar
i am getting the same system installed at williams performance now. bought it from lonnie. lonnie was very helpful.
Old 02-27-2009, 06:49 AM
Big Bird WS6's Avatar
lonnie,
is the aem or the versa a better controler system?
Old 02-27-2009, 08:46 AM
LS1TECH Sponsor
I've have seen good results with either & costs are similar, so it is matter of personal preference.
The plug-n-play harness is now available for the VersaFueler, so either can be provided.
Old 02-27-2009, 10:08 AM
i dont know which is better. if i was a newby on it. which way would you push a customer?
is there a size difference in the unit?
Old 02-28-2009, 02:36 PM
I am working on it! Two weeks from today I am heading down to Williams Performance and we are going to put the AEM box and 96lbers in. Hoping for that magical number but we will have to see. I think it will be close. I know I have the right fuel system now so we I will keep you posted.
Old 02-28-2009, 11:19 PM
jmdgto's Avatar
thanks for understanding and your help about the motor issue i have. you are a stand up guy and i will be dealing with you on future purchases. tks lonnie
Old 03-29-2009, 08:49 AM
I just installed the AEM converter and the plug and play harness. Check this thread out.
https://ls1tech.com/forums/fueling-i...-feedback.html
Old 03-29-2009, 09:30 AM
MY99TAWS6's Avatar
Well if don't change out my ecu for aem or fastxfi or big stuff or whatever will be also getting a driver box and going up to some bigger injectors. Also getting a double pumper fuel setup from lonnie hopefully getting my old bucket out today so can send it off tommorrow.
Good to hear about your results hope mine are similar.
Old 03-29-2009, 10:44 AM
Good luck with your setup. If you haven't dealt with Lonnie before you will not be dissapointed.
Old 04-12-2009, 08:51 PM
Look what we did this weekend with the double pumper from Lonnie this weekend!!! This is through a 4l80e tranny to top it all!
Old 04-12-2009, 09:34 PM
theblur98ss's Avatar
Yikes 1019 through an 80 is very impressive. That's gotta be close to 1400 at the crank I'd guess
Old 04-12-2009, 10:40 PM
Thanks. It is really getting it!
Old 05-21-2009, 02:51 PM
1INSANEGTO's Avatar
Yup good kit. I had the first one Lonnie every built for the GTO's. Top Notch stuff.
Quick Reply: Lonnies Performance double pumper kit
