"BRAKE" light won't go Off?!?
My "BRAKE" light on my dash for my e-brake will not go away. I'm sure my e-brake is all the way down. What could be causing the light to stay on???
im having the same problem, I just swapped all 4 rotors, and installed hawk pads, but Im gunna try bleeding the brakes again, and go from there myself, if it fixes it, Ill let you know
good luck
good luck
Anyone know how to get the e-brake handle off?? I raised it and looking from the driver side, see a small circle, but there isn't any spot for a torx head or phillips, etc.. It's just smooth.
EDIT: I finally found some stuff on it.. guess it's riveted.. great..
