Timing chain question
As I have mentioned many times before, I am camming my 01 T/A WS6. Well today I started to do my valvesprings and noticed that my timing chain seems kinda loose. Is this normal on an LS1? I know my friend said when he rebuilt his trucks motor he remembers his stock chain being loose a bit. However it just doesn't seem right for it to have soo much play in it. There is maybe a 1/4'' of play on each side, someone please chime in!
Alright thanks guys, I was considering replacing the chain with an LS2 chain or a double, however I really didn't want to take the oil pump off. Im glad to hear its a normal amount. I hear changing the timing chain isn't as neseccary as people make it to be.
^^^x2 It will only add an extra hour or so to your project. But if it breaks in a few months, then you'll have a much bigger project on your hands. Might as well just beef it up while you're in there and it's only like $35 for a new LS2 timing chain
Replace it... Ls2 timing sets are much nicer. I just changed mine, it's not so hard. I seen a post on here a few weeks ago where the TC came off and got trapped between the crank gear and the block... It ripped the front of the block off....
