lingenfelter/weiand intake question...
I picked up one of these manifolds for a good price w/ a direct port kit plumbed into it and was wondering what intake gaskets to use and what about the coolant lines underneath? Will the pre ls6 ones work or do i need the later style?
you have to use the ls6 lines.....and any part store can get the gaskets....advance auto ordered mine twice.....and there not cheap......good manifold they do really well once ported......
hmmm, it really looks like it should fit, maybe ill sit it down and take a look. Ill have it ported once i decide to get heads but for now i got it because of the good price and the direct port kit. What do you ask for when you called advance? From the speed shop i just talked to they said the gasket set was 45$ w/ all four gaskets (plenum cover, tb, and intake port gaskets)
Well it most certainly doesn't fit, im going to try to pick up the 01 lines and use two of the fronts like ls1howto.com does. It also seems like the intake is getting slightly hung up on the knock sensor wires, i have removed the clips and it may still be a problem, any ideas?
